Fuel Rail Pressures
Fuel Rail Pressures
Hi Gents,
I'm trying to run down a problem that I am having with the XFR sputtering around 5800 - 6200 RPM. It has only intermittently thrown the P0087 code (Fuel rail/System Pressure - too low). So far I have changed the "in-tank" fuel pump and have a new fuel pressure sensor waiting to be installed. I am logging the car with Torque Pro and it shows the Fuel rail pressure at 525 - 550 PSI range at around 6000 RPM (WOT). This seems very low and was curious what the correct pressure should be? Currently, at start-up, it is fine at 2100 PSI and I believe the idle is in the 500-600 psi range.
Hi Gents,
YamahaRick (04-30-2021)
It cannot be the in-tank pump because that only primes the system and starts the engine. The 2200psi pump is off the camshaft and the crankshaft If the workshop manual I read was correct. I would think TPS sensor or one or both of the MAF sensor that are known to go bad that would cause that. Try cleaning the MAF's and see if that helps
Do you notice what the AFR ratio is when this is happening? The Jag doctor told me fuel injectors were common to lock open at high rpm due to age and high pressures over time. If you knew if it was running rich or lean it would tell a better story. Also you probably have but have you checked your spark plugs and coil packs? If there was no spark in a cylinder it would be have a rich AFR and misfire which would tell the computer to pull back the pump pressure.
Here was that older thread that details my same scenario - https://www.jaguarforums.com/forum/x...00-rpm-168544/
Cello5887
06-22-2019 12:57 PM
