Fuel rail shraeder valve
That is what I was worried about! I am in the 3.0L, but still have 2000+ of psi in the fuel rail.
Since using the supplied T- fitting for the fuel is looking like the only option, where exactly is that line located?
I am actually thinking of going with a direct port system eventually. The only reason for this is that when I had the intake and S/C off for the coolant crossover pipe replacement, I got a look at those valves and they were nasty. planning on getting them walnut shelled and having a direct port wet kit installed so I can spray the top of those valves occasionally...just so they stay clean...hehehee...I also want to avoid delamination of the coating on the S/C impellers but I think they will hold for a while.
The fitment issues can be dealt with if I am smart about it and the SS tubing will look totally sic....for now I will stick with the single nozzle wet kit.....as soon as I can find info about that fuel supply line
Received 3,229 Likes
Cherry,
Here is a link to a detailed PDF about the AJ133 V8 which might help you as the fuel injection system on your AJ126 V6 should be pretty much identical: https://www.dropbox.com/s/8y4iax9hm2...%20V8.pdf?dl=0
