Most likely the wiring harness that runs into the trunk. The wires eventually break from repeated open and close and it gives open error, sometimes the lock won't open with the button etc
It's in a rubber boot by the right hand trunk hinge. Pull back the rubber and have a look for a broken wire
You can splice it easily else a new harness isn't expensive
