Gauge Cluster fading in and out...
Old 10-09-2014, 12:40 AM
RodTee XF's Avatar
Default Gauge Cluster fading in and out...
Have any of you experienced the electronic display between the speedometer and tachometer fading in and out?
Old 05-11-2015, 02:54 PM
RodTee XF's Avatar
BUMP....has no one had this happened??
Old 05-11-2015, 03:22 PM
chXFS's Avatar
Mine does too every so often. I don't know the fix.
Old 05-11-2015, 03:59 PM
RodTee XF's Avatar
Thanks for the reply...was starting to think mine was the only one. Like you mine only does it every now and then but its annoying...
Old 05-23-2015, 04:06 AM
fletch106's Avatar
Yes, mine did that. The fault lies within the cluster. It's not the electrolytic caps as I thought it could've been. Must be a surface mount component gone bad, but I'm not skilled enough to troubleshoot those (and not without a schematic from Visteon). Fixed it with a swapped cluster. You need to be good with SDD and a Mongoose cable to do key unprogramming, reset immobiliser and reprogramming of keys on the new cluster. Or pay the best part of £1000 to have Jag do it!
Fletch
workworkwork
10-23-2015 10:26 AM
emilime75
XJ XJ12 ( X305 )
10-19-2015 09:55 PM
vwbusbits
10-13-2015 03:43 AM
mrplow58
09-30-2015 08:56 AM
Quick Reply: Gauge Cluster fading in and out...
