Gearbox compatibility
Hi guys could someone in the know give me some advice I ve a slight prob with my gearbox as in something broke inside and got spun around the torque converter and spat out via the rubber bung hole it still works ok don’t leak the question I want answering is would a 5.0 box fit my 3.0 petrol as getting a box for mine is like rocking horse s**t and the north end of 2.5k any advise would be appreciated
First off- I don't actually know...But you did stipulate "any advice" so maybe this will help you research further for yourself if someone with specific knowledge doesn't chime in.
So, looking up your specs online you have a 6 speed gearbox ? My SV8 4.2 litre has a ZF 6HP26 gearbox. These were apparently commonly used in other brands such as BMW ( or was it Audi ??) and maybe that is in your car too... dunno. I think you will have a broader choice once you know what gearbox is in your car and look for that particular gearbox.
edit: 'cos you can't just throw in , for example, any 8 speed rather than 6 speed , if that applies re: 5.0 car, and just drive away !!
daz2708 (11-14-2021)
Received 3,208 Likes
You need to determine which exact gearbox you have and replace it with the exact same type.
All V6 and V8 XFs from 2008 to early 2012 used the ZF 6HP26 and then they switched to the ZF 8HP70, except for the XFR which didn't switch until a year later.
Except I believe the early (2008 and 2009?) petrol V6 with the Duratec engine which I think used a different and lower rated ZF 6 speed 'box.
Then when the AJ126 V6 (supercharged) came out and replaced the 5.0 V8 NA (2013?) it also used the 8HP70.
If your XF V6 is one of those early ones then you can't use the 6HP26 but if it is as I suspect a later one then you need either the 6HP26 or the 8HP70, depending on which one of those you already have.
And AFAIK it needs to be a Jag one and not one from some other car such as a BMW otherwise it won't bolt up.
