Gearbox fault
My jag 2011 xf reverse doesn't moves sometimes.
R symbol blinks but no moves.after try D mode for a bit forward then R means it will works or switching off the engine then restart also working fine otherwise I feel better in fwd gears.
Also I'm feeling like auto gear shift taking time to shift to next gear and pick-up issue.
Can anyone facing the same problem means pls let me know with the solution.thank u so much in advance
