Gearbox Fault, DSC Not Available, Parking Brake Fault & Low Washer Fluid Lights on
My 2009 Model XF 2.7D Luxury has been trouble-free in 3 years of ownership. Last week however, the low washer fluid warning message came up when the water bottle was full. I drove the car this morning and the Gearbox Fault, DSC Not Available, Parking Brake Fault messages came up as well! It doesn't seem very likely that the car has suddenly developed all these faults. It certainly drives fine as it did before. It seems as though there is some problem with a sensor or control unit flashing up these incorrect messages.
Is there anyway of clearing all the messages by going to a independent with a fault reader or will it be a main dealer job?
The low battery light has occasionally come on since I've had the car - I got the battery tested shortly after I bought the car and it was fine. I've started doing some research online and maybe it's possible the battery is low and this is causing problems? I've also read that if there is a fault with the parking brake switch, this can throw up many incorrect fault codes.
Greatly appreciate any advice/experience/information
I've just made a quick video to show the warning lights at the start-up:
https://www.youtube.com/watch?v=kIgI...ature=youtu.be
Leslie Graham (Levitikon) (06-01-2019)
BrentGardner
28
04-26-2024 03:08 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
