Good source for replacement center speaker Grill?
Silly me pressed down too hard on the dashboard center speaker grill while wiping it down and (I'm assuming because it has been exposed to the sun a long time) it "shattered" into about a dozen little pieces. I managed to retrieve them all and superglue it back together so there is something at least covering the speaker, but it's U-G-L-Y. Is there a good supplier for a replacement (used or salvage is fine)? Color is truffle brown.
Thanks!
Thanks!
My center speaker grill is also cracking. My dash is warping and some of the stitching is tearing apart as well but I can live with that since it's not that noticeable yet. I'd like to know if you found a center speaker grill though because mine is about to break into a hundred pieces as well.
Aftermarket and Jaguar don't go together.
How many speaker grilles do you think they could sell?
Not anywhere near enough to make money. The only source is Jaguar.
One good thing I have found out about Jaguar is they do keep parts availablebetter than a lot of cars.
So you can at least get one but it might be expensive too!
My car had no warranty on it at all and Jaguar covered it. That wasn't even the reason I brought it in, they saw the wrinkles and the cracked speaker cover and said they were going to replace the dash under their warranty. So there should've been a service bulletin or something, or maybe some dealerships take care of their customers better than others.
chuckh007 (09-12-2014)
Tanman (09-25-2014)
Hi guys,
Car wash guys damaged the centre speaker on my 09 XF while wiping the dash down.
They reimbursed me for the part and I purchased it from Jag - any tips on removing the speaker grill/cover? Does it just pop out? Any advice on tools I should use to pry it out?
Thanks!
Thanks!
Call Jag USA and complain... they worked with me and I paid $850 or thereabouts... can't remember if I paid for the part or the labor...
PinnacleWax
Detailing / Car care
08-26-2015 11:44 AM
