Guys a Truly worthwhile read / dealerships
So- most of u have read my rantings-
first TOMS won't recover spins constantly
then battery warnings
the gear box warning
Finally said screw it -
a) went to 2 local shop (one pep boys) had load test-
BATTERY - low but fine (this is from computer)
alternator - good
starter - good
I give up bring reports from this board and load test reports.
advisor noted them but does not show them to tech
i wait an hour sneak into tech room advisor flips but i had 7 min with tech.
MY battery is jag installed 6 months.
advisor ends it with -
a) u have defective battery - under warranty
and the module and receiver are about 700 with labor
I ask how much for parts? module for example-
he says $380-400ish.
i say what part #
THEN SAY HERE IS SAME JAGUAR PART OEM VIA MERRIAM FOR $168
HE SAYS BRING IT IN AND WE WILL ONLY CHARGE U $300 FOR INSTLALL AND REPROGRAM.
DROVE HOME 50 MILES NOT ONE TPMS.
TODAY IT WENT OFF ONCE/TWICE-
SO I BROUGHT IT TO LOCAL SHOP AND DID WHAT OTHER SAID -
ENGINE OFF - TOOK TIRES DOWN TO 16LBS
ENGINE ON INFLATED TO 35LBS.
COULD IT TAKE DAYS TO READJUST??? COMPUTER- MODULAR??
alternator - good
starter - good
i say what part #
carcycle
09-07-2015 10:22 AM
