Hacking NAV/Entertainment System for Wallpaper
Hi All,
I have a 2009 Jaguar SV8 and I was hoping there was a way to hack the system to allow me to upload my own wallpaper/screensavers.
Does anyone have any suggestions or tricks to be able to do this? I've already gone through the engineer/service/nav secret menu's and haven't found anything of interest.
Please do let me know.
Thanks!
Thanks!
woodyp (02-25-2013)
I have documented this hidden menu in the Nav screen that can give you access to many options. I am not sure which code will allow you to add a wallpaer but I know it can be done here as that is how the techs do it. They add the Jaguar, Bower&Wilkins,etc wallpapers in this menu. Just need to type a few more codes in to get the right one. Enjoy:
There is a secret diagnostic screen in the Navigation System on the XF.
WARNING ? IT IS SAFE TO ENTER DIAGNOSTIC MODE, BUT CHANGE SETTINGS AT YOUR OWN RISK.
To enter diagnostic mode do the following...
1. Press the Navigation button on the Menu.
2. Accept the Sat Nav Disclaimer Message.
3. Enter Diagnostic mode by pressing the top centre (Top Edge) of the screen for approximately 5 seconds.
4. Enter a pin code of 660, 661, 662, 9448, 295660
5. It is safe to browse the settings, but change the settings at your own risk.
Other pin codes allow you into different settings.
see http://www.xfforum.c...php?f=26&t=1432 for discussion thread
[Diagnostic Screen Access]
1.With the vehicle at rest, place the ignition switch in either
"ACC", "ON", or start the engine.
2.On the "Menu" screen, press the top center of the screen
(circled portion in the image to the left) for more than three
seconds.
3.Enter the PIN code, and then touch "OK".
660: Diagnosis Menu screen
661: System Check screen (DTC code verification screen)
662: GPS Information screen
4.The diagnostics screen will be displayed.2. DIAGNOSIS SCREEN
2.1 Diagnosis Menu
? Transition to various check screens from the Diagnosis menu screen.
seconds.
2.1 Diagnosis Menu
The following 5 users liked this post by BigCat09:
Louis McMahon III (09-26-2013),
Mdm (10-16-2012),
n8ertot (08-10-2015),
Pb-ft (12-11-2012),
TAhlberg (11-12-2012)
Pb-ft (12-13-2012)
Received 2,192 Likes
that stuff is engineering and tech line knowledge need to know, and well we just havent needed to know. theres alot of stuff that these car do and access programs etc.. but many is done and used at build and port or in testing.
Pb-ft (12-13-2012)
