Headlight washers - no, thank you
Does anyone have any ideas on disabling the automatic headlight washers? I live in Naples, FL and never have the need to wash my headlights.
It never fails where I just spend hours washing the car and then a day later clean the windshield and have those stupid things pop out and spray washer fluid all over the hood of the car, leaving residue all over the front end.
Certainly not the end of the world, but I'd rather do without, thank you very much!
Is there a fuse for them that I could simply pull, or better yet.. an option that I can disable?
Input very much appreciated!
The only time I think these might be useful would be in snow/salt winters and then need the little wipers. I have disabled them on any of the other cars that I have had in the past. On one car, I just pulled the water feed to them and pluged them up. Don't know how to do it on this car though.
I live where headlight washers are essential. The newest high pressure spray washers no longer need wipers. They do mess up the look of the car but then so do the windshield washers so it isn't clear to me why a spotty hood is different from messed up side windows ( a big defect in our location as you can't wash the side windows) and a spotty roof and rear deck.
Leaving your headlights OFF means the headlight washers don't operate.
The other thing you might do is to leave the washer fluid tank mostly empty as the headlight washers don't work if too little fluid is present.
Finally, reconsider whether you need headlight washers. In reality you do need to clean your headlights if your windshield needs cleaning.
In Europe you must have them if xenon headlights are fitted, and only xenon equipped cars were delivered with headlight washers in the US. Our Canadian cars got them standard even with halogen lights. If you have xenons you must use headlight washers or the beam scatter caused by dirt on the lense distracts other drivers. That's why washers are mandatory in Europe when xenon headlights are fitted (headlight aiming levelers are also required).
I can only speak for the XK series but JTIS says
The headlamp powerwash system incorporates a telescopic nozzle unit mounted in the lower section of each headlamp. Each nozzle is connected via snap fittings to a powerwash pump mounted above the windshield wash pump on the rear face of the washer fluid reservoir.
so you should be able to pull the pump connector and still have windscreen wash.
It's the methanol anti freeze that takes the wax off. I solve that by never waxing my car. Contrary to urban myth, car paint does not need any protection. If you wax a car you have to keep on waxing it unless you completely remove the wax.
I find the talk about "preserving the natural oils" in the paint particularly amusing. That would presumably be the plastics modern car paint is made from? Paint eventually oxidizes but that can readily be removed and a fresh layer of paint revealed, that is indeed what car polish does. Wax just fills the microscratches for a short period. Ironically, the most common cause of microscratching is polishing incorrectly. The second most common cause is use of automated car washes. Thirdly, incorrect hand washing by using pressure washers causes much of the paint damage you see. Nothing like sandblasting your paintwork with a pressure washer!
I wash my car as infrequently as possible, especially during the winter. The grime actually protects the paint from damage, believe it or not.
Swimref you are right, but I have only had this car for a few months. It will inevitably see some rain. Probably in the next few days as it is supposed to be raining Christmas where I am going for the Holidays.
To each his own. But to me, there is nothing more beautiful than a freshly polished car. I use Nu-Finish, a polymer polish. I have used it for over 25 years with the best results. Easy on, easy off. I have converted many a professional detailer. Notice how many brand name car wax makers have recently come out with their own polymer polishes.
I was able to easily disable the headlight washers on my '11 XJ. I have done with each of my Jags since I live in San Diego where headlight washers are unnecessary and prove to be a nuisance. For the X350 XJ, merely remove the 30A fuse from position F4 in Engine Junction Box. Note that this has no impact on operation of the windshield washers.
I almost never use the washers. If the windshield is dirty, I keep a supply of microfibers and "Perfect Glass" from Home Depot/Bed Bath and Beyond in the trunk and just clean it by hand. Takes less than a minute to get a perfectly clean windshield throughout without the wiper look.
Even without the headlight washers dirtying the front of the car, the windshield wiper washers get the roof and side windows dirty.
FS[MidWest]: 2001 Supercharged Vanden Plas
Col. Sandurz
09-28-2015 07:29 PM
