Help!! Need Crank Main and Rod Cap Torque Specs
Hey Guys I am in the process of assembling the bottom end of my Motor and I am looking for specs on the Bolts for the Main Caps and The Rods. Does anyone have the specs and order in which the bolts must be Tightened for the Main Caps as well as the specs for the Rods? I am looking for the 5.0L SC or 3.0L SC specs. Any help would be greatly appreciated.
Thank you,
Dragos
Thank you,
Dragos
There is no workshop manual on internal engine rebuilds.
You may find my rebuild thread helpful, if a little long
hi. Any chance you might have the conrod cap torque specs for a 2.2 diesel xf 2012?
sharief
Or perhaps how would I know the bolt size of the 5.0L? I am taking this job on souly by touch and feel helping a friend out and is my first xf diesel changing big ends on so just want to be sure I have everything right before I start assembling and not through more damage into the mix
So I’ve been told but also told that it was a ford engine lol So I am definitely not finishing this car off as the con rod caps will never be torqued to spec at this rate. This car is literally only missing these torque specs.
From my experience all torque figures are related to the bolt size and length not the name on the engine or the exact design. I'm sure if you Google engine bolt sizes v. torque you will find what you need. At the end of the day that are just bolts that need to be tight.
Something like this.
https://images.app.goo.gl/kUBgk9Fobf8XzxXq9
