Anyone know what this part number is? Its a clip that holds carpet in place under passenger side dash. I broke it while trying to remove the carpet to replace the cabin filter.
Ah, yes, the flimsy, floppy, useless carpet above your feet in the front seats. I hate that stuff. Both sides on mine are basically droopy blankets. Such a terrible design.
Side note, the hood liner on my Audi uses those same clips, only a tad smaller. Once removed, I always try to open the clips up a lot wider, so they'll have more tension when reinstalled. I'm probably playing with fire, but I haven't had one break yet.
Glad JW chimed in with the part #.
They are called "hush panels" and I largely fixed the sag/droop on my old XFS and XFR by sticking a thin strip of double sided tape along each front edge of the metal where the clips go in and pushing the panel up to the tape. The F-Type has no such thing and some have commented on the bare unfinished look under the dash and glovebox.
The front of the panels aren't where I have the problem, it's the rears, near the firewall. I ended up punching holes in them and using zip-ties to hold them up. Is there a better way?
Whenever I needs parts, the FIRST place I look is Jaguar. This tells me two things:
1. availability
2. cost - now I have something to compare
Sometimes cost comes as an unpleasant surprise but quite often it is sufficiently reasonable to make searching elsewhere a waste of time. The C2C28479 clip is a case in point:
Aftermarket suppliers aren't always cheaper. However, you won't know how they compare unless you check Jaguar prices first.
