Hit a pothole and have this hanging from the bottom of my car
That looks like the Tire Pressure Monitoring System (TPMS) receiver. Does it look like it came out from under the wheel well? The receiver is what picks up the signal from the TPMS on each wheel. Looks like you can just put it back into the brackets.
More information here:
https://www.jaguarforums.com/forum/x...d-sorry-90875/
![](https://www.jaguarforums.com/forum/attachments/xf-xfr-x250-44/36199d1363143821-tire-pressure-monitor-revisited-sorry-driver-front-antenae.jpg)
JimC64 (12-01-2014)
Received 9,007 Likes
There is nothing worse than having headlight fluid at the wrong pH, it can really throw off the light dispersion ...
It's definitely the TPMS sensor. There's one at all four corners of the car (reading the sensor in each wheel/tire). Potholes can dislodge them. They're fairly easy to put back into place, as they just slide into a type of channel - that's probably also why they're so easy to dislodge.
Swimref (12-07-2016)
I agree....that's why I secured mine in place, using a "wire tie".
BrentGardner
28
04-26-2024 03:08 AM
