Horn sounding twice when unlocking doors
HI Guys,
I wonder if you can help me.
As of yesterday my 2012 XF has started to sound the horn twice when using the fob to unlock or the door handle. This happens both on single and dual entry.
Can this be set up so as not to sound the horn on the control screen?
Thanking you in advance
Steve
Steve
Welcome to the forum Steve,
I've moved your question from General Tech Help to X250 forum. Members here with the same model will be able to help.
Received 3,269 Likes
blyth63 (04-23-2015)
I had the same problem
Ill just tell you what I experienced even though its on the other page. So I couldn't lock my door and it would beep everytime I tried. The only way was through the actual key insert. Car starts and everything was good but the dashboard indicated my trunk was open. I checked it out but apparently something on the inside broke and my car thought the trunk was open. So if there is a door open or not closed all the way, it will beep and it will not lock... hope that helps. And yeah look for others posts first! It Def helps get answers faster
kabs3012
09-12-2015 10:40 AM
