Hi all, I'm not sure who serviced the Jag before I purchased it, I'm the 2nd owner.
But I noticed this part of the air intake that connects to this is broken and they've used electrical tape as some sort of temporary fix. I can't seem to find much info the hose itself, but trying to find a replacement for this section of the air intake is proving difficult.
Never had the AJ133 NA, I had a 2010 XFR with the AJ133 SC, but I reckon that is the join between the two hoses of the secondary air injection pump and you probably need both hoses.
Part numbers C2Z4526 and C2Z4527, parts 5 and 6 on this diagram: https://parts.jaguarpalmbeach.com/a/...S/4750337.html
Ah okay, so its something that I should try to fix as soon as I can.
The part I that needs replacing is that centre Y section of the air intake as it connects to that air injection hose, the hose isn't damaged itself but what it connected to on the plastic is.
