How do get the XFR to 600hp
are you referring to the upper or lower pulley? The lower pulley will get you the large gains, but it is closer to $900. The upper pulley is good for a few extra HP (maybe 15-20HP) but will give you a good bump in low end torque...however, it is a PITA to install and you pretty much have to destroy the OEM pulley to get it off. Go for the lower pulley if you can. It will really beef up the responsiveness and the torque/HP increase can be felt throughout the powerband. You really wont feel the upper pulley on the XFR.
