How to Dyno Newer Jaguars
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
I would like to know how you put these new Jaguars into Dyno Mode to run them on the Dyno?
I have tried 2 different Dyno shops wit hmy XFR and have had some issues dyno this car properly. I uncliped and removed the coolant bottle to get access to the coil pack/inj wires for a tach signal/reading. I turned DSC all the way off and put gear in S mode and attempted to use 4th gear as my pull. But soon as I floor it the car will kick down to 3rd gear. I think if I do not floor the gas all the way but rather hit it down to the micro switch for the kick down gear button it would hold 4th gear but I am not sure. What rpm/speed should I start with in 4th gear for dyno runs?
And I know there must be some Hidden Menu, Dyno Mode, Secret Menu, Engineering Menu somewhere in these cars as Dyno Mode is needed all around the globe. So how can I keep the cluster from giving tons of faults when dyno , get a good tach signal, and hold 4th gear please?
