How fast in snow tires?
Received 6,330 Likes
Received 2,263 Likes
No need for that. Have a snowman and some beer instead:
The two make a great combination. We use winter as an excuse to drink beer faster when outside- wouldn't want it to freeze!
Snow tires are actually delicate to a certain degree, not primarily from a speed point of view, but from temperature. The rubber compounds are designed to remain flexible at -20C temps or even colder. No flex, no grip especially on ice. The trade off is if the road temps are higher than +10, the rubber wears very quickly. Installing a new set of expensive tires too early in the season can mean they're worn out before the first flakes fall. If you wait too long and there's a sudden storm, well- you're walking or taking the bus.
Speed rating is one thing and grip is entirely another. The winter tires will not explode until you exceed their designated speed rating but driving at high speeds on winter tires in warm temperatures is a potentially alarming situation.
So if you are asking whether the winter tires will stay in one piece at high speeds then the answer is yes as long as you do not exceed the maximum speed rating marked on the tire. However, if you are asking whether it is safe to drive on your winter tires at those rated speeds in warm weather, I say not really. Only if the roads are colder than 7C then winter tires are actually safer at high speeds than summer tires with the same speed rating. This is assuming the roads are bare. If snow or ice is possible then you must drive for the conditions and not the speed capability of the tires.
Bruce
FS[MidWest]: 2010 XKR convertible
JaguarJoseph
09-16-2015 11:19 AM
