How long will my XF run like Poop?
The dealer reset the tranny and engine ECU to try and fix the shifting issue I posted about a few weeks ago (hard shift into 1st coming to a stop).
The car is very boggy off the line. Boggs bad. Turned the DSC off to the first step to make sure the trac control was not killing it and it still Boggs.
I have only driven it for about 10 miles since the reset, but it was with the "flag" button lit.
I will put 40 miles on it tomorrow for work and I hope it starts running right again.
BTW - gas is good, 93 Shell. Same gas I always run and am n the middle of a tank now.
Not to sure about the bogging issue. I drive it in normal mode almost 100% of the time and wont step on it hard unless I need to. I don't think it really bogs for me but definitely has a delay a bit it seems. But the gas milage is "good" maybe because of it.
Did the aggressive shifting stop? Mine certainly has. Feels like a new car again and I am enjoying it more!
I can imagine with the extra 100hp. I rarely even shift it down to first, cause if i do and keep my foot down, it just starts roasting the tires.
Try, this and see if it helps -- nothing to lose.
jagular (10-03-2012)
