How much room in lower grill?
How much room is there behind the lower grill on a 2010 XF supercharged? I am looking so I can size a front mount heat exchanger. I was looking to place it below the front support, but don't know how long or how tall I can go. I was looking at one that is 30"x3"x6" and a dual pass, so both connections are on the same end, as the pump.
Anyone have any experience with the room under there? any pics or measurements?
So hot coolant would go from the top mounts, down to the factory cooler, out the pump on the end of the cooler, into the aftermarket cooler, then cool coolant back up to top mounts, and so on.
Received 3,217 Likes
IansJagXF
02-21-2018 10:08 PM
