How often on oil changes?
Oil change
Recommended oil change intervals were different on the 4.2 litre and 5.0 litre engines. I believe the recommended interval was 10K on the 4.2 litre and 15 K or 1 year on the 5.0 litre. The oil in the 5.0 litre has been the subject of some debate in this forum. It is not obvious whether it is a synthetic, a combination of synthetic and standard oil or standard oil from the part number and description.
My BMW uses synthetic pure and simple and requires a change every 1 year or when the service indicator shows a need for a change (this depends on how you drive the car and the conditions under which the car is operated) whichever comes first.
I tend to agree with Jagular on oil changes. Although there are a lot of differing opinions on whether more frequent oil changes help, the old reason, which was due to more rapid oil break down and the fact that engine tolerances tended to result in more metal in the oil, are no longer valid. The manufacturer has done a lot of research and unless the marketing guys came along and told them that they had to have longer intervals between changes, I will go with the manufacturer. I am sure that if these cars needed new engines after 100K miles due to servicing when the manufacturer recommended , there would be serious consequences in the market place. I try not to second guess the engine designers.
As I understand it the 5.0 comes from the factory with Castrol SLX 5W-20 and Castrol says that it's synthetic as to if it is group III or IV I have no idea. To be able to go 1 year or 15,000 miles it had better be good oil and conventional oil just isn't going to cut it.
The limit on service life for modern synthetic oil is the filter capacity. Once per year is still recommended due to moisture and fuel contamination issues. The oil has no known service life limit under currently known conditions. Change the oil and filter once per year regardless of mileage.
Pulled this from an ebay search from another website. This was posted by someone in 2009. I would obviously not take it as gospel, because it is less than second hand. Maybe someone here can validate?
"Jaguar and Castrol - two legendary English companies - have teamed up to develop a new 5W-20 synthetic motor oil which enables the AJ-V8 Gen III 5.0L engine to achieve high horsepower and torque without impacting fuel economy. Previously oil changes were required every 10,000 miles. Now that has been extended to 15,000 miles or 1 year, whichever comes first. The new oil, Castrol Professional FuelSaver SLX A1 5W-20, is exclusive to and must be used in the new 5.0L AJ V8 engines.
Benefits of this new oil include:
· Stable viscosity for sustainable performance
· Improved engine cleanliness and engine protection
· Better ability to compensate for various driving styles
There are several features your new Jaguar customers should know about:
· The new Castrol oil, SLX Professional 5W-20, is the only oil recommended for the new 5.0L AJ V8 engines
· A service reminder in the Message Center lets the driver know when it's time to change oil
· Service Interval is every 15,000 miles or 12 months, whichever occurs first. It's important that your customers visit your Jaguar dealership yearly for annual service
· The first scheduled maintenance service visit is Complimentary
· Maintenance Interval Message automatically appears when it's time for service
· Checking the oil level is simple using the built-in "digital dipstick" on the car's onboard computer. The new engine does not have a traditional dipstick
The Jaguar/Castrol co-engineered 5.0L engine 5W-20 synthetic motor oil is the only lubricant completely tested to be compatible with Jaguar’s new engine components and other fluids and sealants. No substitutions should be made as the warranty coverage requires the use of the proper Jaguar specified lubricant."
For those who are less trusting and more research minded, below is a link to an oil testing company that will tell you more than you likely want to know about your oil. I have never used them. I think it is $25. If nothing else, their website has a pretty humorous read (see FAQ). Also, check out the June 2, 2012 newsletter if you think you oil hasn't been changed enough.
What is Oil Analysis
P.S. I am not affiliated with this company in anyway, and find them to be quite funny and informative.
It will probably surprise you to discover the viscosity of engine oil used in F1 these days. Every bit of viscosity wastes power.
Best oil website
http://www.bobistheoilguy.com/
Best oil website
#28
There's a good bit of evidence accumulating that frequent oil changing does not accomplish what most folks suppose: less engine wear. Actually, maybe the opposite. Ford-Conoco has done two studies, reported in SAE papers, that show the most engine wear occurs with new or fresh oil during the first 3000 mi of use. So the more often you change the oil, the more you are putting your engine through that cycle of sub-optimal lubrication during the first 3000 mi. The Effect of Oil Drain Interval on Valvetrain Friction and Wear.
As for the 5w-20 viscosity, someone mentioned Formula 1. I read a little while ago that Ferrari uses 5w20 for qualifying, and IIRC, 5w30 for the race (maybe it was 5w20 - - I can't remember). As is often said on the BITOG oil forum, "thin is in". Doug Hillary, a lubrication engineer who often posts on BITOG, reported a while ago that some BMW teams at the ADAC 24 hrs of the Nurburgring, were using 5w20 engine oil.
Oem oil change intervals are based on a lot of field testing in cooperation with their lubricants partners. OCI's of 15000 mi are not that unusual today. That, plus most cars today have OLM's (oil life monitors) in the crankcase. Some are very sophisticated (a Bosch OLM actually measures the oil viscosity by sending sound waves through the oil). They are not going to let you trash your oil.
Oil change intervals
2012 XF NA
#31
#32
#33
#34
All I know is that after 221K miles, my 2000 XJR (with Nikasil engine, mind) is still in fabulous mechanical condition and, thanks to 5K service intervals from new with full synthetic, still looks like it did internally when new--i.e. clean as a pin.
Oil is cheap enough, and I've seen enough positive results on enough cars, that I'll stick to 5K service intervals.
#35
Just bear in mind that 2000 was 13 years ago. What worked then may not be appropriate now.
Your engine was designed to run on 5W 30 mineral oil, not synthetic.
New Jaguars run on 5W20 and synthetic oil is preferred, for some cars it is now essential.
The points being made are that new engines should not have their oil changed as frequently as was desirable in times past.
I changed my 1986 SAAB turbo from conventional oil changed at least twice per year every 7,500 km (approx 5,000 miles) to fully synthetic once per year or 16,000 km (10,000 miles). That engine ran flawlessly for over 300,000 km and 20 years. So, anecdotally, neither of us proved anything except I saved a lot of money on oil changes.
All my current cars get once per year or 16,000 km fully synthetic oil changes. Our 1991 Alfa Romeo runs flawlessly at 210,000 km and has followed this factory directed oil change schedule from new.
#38
Perhaps I am wasting my money, but it's a pittance compared to the alternative.
And yes, although my engine was designed for conventional oil, I was lucky in that the first owner elected to go synthetic right out of the chute and stuck with it until I bought the car from him. I work for a Jaguar dealer in service, BTW, so I'm well briefed on the new cars' oil requirements. And, FWIW, if the car isn't going to be kept past warranty, go ahead and do the 15K services. Personally, I wouldn't if I were planning on keeping one well into and beyond the 100K point.
#39
#40
It's actually fact, not opinion but I'm not trying to change your mind just convince others not to waste money and unnecessarily burden the environment. It is a fact that your engine wears more when it has to restart with no oil pressure than it would while running for many hours. Every oil change shortens engine life.
