How to Perform a 4-Wheel XF-SC & XFR Brake Job "HOW TO"
#61
Received 3,204 Likes
The following 2 users liked this post by OzXFR:
Jeff Murray (04-11-2021),
Na5h (11-18-2021)
#62
Originally Posted by silvertonesx24
Just to help out anyone who is having trouble with it, I have a XJ 5.0 SC and XKR 4.2 SC and the process is pretty much the same on all of these (XKR has torx instead of hex socket). But on all 4 rear calipers, retracting that piston required cracking the bleed nozzle (10mm) to relieve pressure enough to be able to retract the piston.
I used SDD to put the caliper in service mode, and I have the proper windback tool- and yet all rear calipers required this extra step to retract enough to fit new pads in.
#63
Much the same here, I have changed the rear pads a few times across XFS, XFR and F-Type and all I have ever done is draw a bit of fluid out of the brake fluid reservoir to ensure it didn't overflow when I wound or pushed the pistons in. Each time I need not have bothered as the level in the reservoir hardly budged anyway which I put down as due to the "old" pads being not all that worn (maybe 1/2 worn max) so the pistons didn't need to go very far back in.
#64
Did my rear pads on a 2014 XKR over the winter. Hardest part was ordering the correct pads. Even the dealer sold me the wrong pads. My XKR uses the same pads as the XKR-S. I used an Autel AP200 dongle to retract the pistons and put the calipers in service mode, and a manual adapter kit to completely scew in the pistons. There was no need to relief pressure through the bleed screw. However, one must unscrew the reservoir cap. I also was mindful of any overflow from the reservoir and never had to remove any fluid. Although, my pads were not severely worn. I reused the original sensor.
#65
#66
On both the XKR and XJ, rear caliper wouldn't retract until the bleed screw is released.
#67
The XFR workshop manual does not mention this as a part of the Brake Bleeding process. So I am assuming that it would not be needed.
#68
