I added a new Rotary Shifter to my XFR
I see, the rotary motion is beneath the selector knob to raise and lower the knob so you can grip it. The knob itself doesn't rotate as it rises and falls. That makes sense from an actuation perspective. Wouldn't it be a simple matter to straighten this out the next time you switched on? Or might it keep rotating around each time you forgot to select P?
Hmm, guess the logo idea may not be a good one.
I am attracted by the grip feature on the re-styled knob. The rubber grip around the knob seems more practical, especially in cold weather if one does not use gloves (as I do not having the nifty heated steering wheel).
Give it a try I'm sure it doesn't turn back when it selects P for you (if you shut the car off in D). At least it doesn't in my car. I mean it isn't a big deal but if we got a nice Jag head centered on there it would be annoying if it was off centered. Something to keep in mind.
Your right, sorry about that. I gave it a try the other day. Well that solves that sorry for the confusion.
Even if the knob doesn't rotate back, Its real simple to just pop the cover off and re position it. After all, you shouldn't be shutting the car off in drive or reverse, I'm sure that can't be good for the tranny if done to often. But, anyway, the cover is suppost to come off simply and faster then the OEM cover, which isn't hard at all to take off. I took mine off today in a minute.
I like the growler idea. Someone please post when that comes out.
#28
I called the dealer today and asked the tech about shuting the car off while in drive. He said that "Its like doing that to any other car, the difference is that the computer kicks in and puts it into park as a fail safe mode". The safety feature is the same as having to put your foot on the brake before starting the car.
He also said that the sudden drop of fluid pressure on your tranny over time may cause problems later. This isn't recommended.
"P should be selected before switching off the engine. However, it is possible to switch the engine off with R, D or S selected - the selector will automatically select P, while retracting into the center console."
There doesn't seem to be any warning against switching off while in drive. There would be little point in switching off a car while in drive in a regular ignition key, because it just creates more steps. 1. Switch off ignition; 2. move transmission to P; 3. move hand to ignition key and twist ignition key once more to full off position; 4. remove key.
#30
#31
Another technique that might work, which I've used for emblem removal, is dental floss. Wet a piece of dental floss that's long enough to hold in two hands. Get it under the edge of the item you want to remove. Then saw the dental floss back and forth all the way through the item. This will get the item off without leaving any scratches on the surface around it.
#36
A member here spotted a new Rotarty Shifter for our cars in the 2012 accessories catalog and I felt it to be a must have. It was a super fast swap and adds a great feel and look. My local dealer robbed me blind for it $159 but I hear Mina Gallery has the same one to offer us and you can get an optional Mina logo or R logo for a topper. I also think it may be a tad cheaper from Mina and it is indeed the same part # and all, just with that Mina special touch to it. Here is a few pix I took so you can see how simple it was and how nice it looks.
![](http://img824.imageshack.us/img824/1229/20120719121109554.th.jpg)
![](http://img854.imageshack.us/img854/6564/20120719120947307.th.jpg)
![](http://img221.imageshack.us/img221/3432/20120719120711942.th.jpg)
![](http://img32.imageshack.us/img32/5766/201207039517113695533.th.jpg)
![](https://www.jaguarforums.com/forum/members/edobernig-107535-albums-pedals-valve-stem-caps-4349-picture-rotary-shift-extended-growler-14283.jpg)
![](https://www.jaguarforums.com/forum/members/edobernig-107535-albums-pedals-valve-stem-caps-4349-picture-rotary-shift-retracted-growler-14282.jpg)
So cool. It really looks factory. It's so simple it was silly. What do you think?
#38
Its a metal key fob. Chrome plated brass with a enamel inlaid Growler. I ordered a wire mesh grill from Mina Gallery for my '04 XJ VDP (post pic.s on XJ 350 page) and there was this key fob added to the order today. I carefully filed off the ring applied some mounting tape and voila it looks seriously factory.
