I Phone interface
I just picked up my 2009 SC XF. Whenever I connect my iPhone 4s all I can do is listen to my library and the home screen just say accessories connected. I cannot go to my main menu on my phone. I want to listen to pandora, what do I need to do? Please help.
I am still new at this forum.
Thanks in advance.
Sunil
Thanks in advance.
Sunil
How is it hooked up? Do you have an ACM installed>? (Audio Connectivity Module)
Jaguar Audio Connectivity Module (ACM) Installation and Tips
Kanchi868 (07-20-2012)
It does have usb port as well as audio jack and one that you can control you i pod from the steering wheel. I am using the that controls i pod from the steering wheel. I tried plugging I pod and it is saying the same thing, accessories connected, would let me do anything on the i pod.
thanks for the help.
Sunil
Sunil
I am pretty sure you plug the iPod or iPhone into the USB port to get full functionality.
However, the iPhone or iPod will not charge through the USB port due to Apple capriciously changing charging voltage to 5 down from 12 and reassigning the connector pin for charging. An adapter cable is required.
