IAT bank 1 sensor 2 location
2015 XF 2.0 turbo
after I replaced both fuel pumps, I tried to reset adaptives but scanner said iat was -40, and wouldn’t allow me to. Checked data and IAT 1 (in MAF) was reading properly. 68, and -40 when unplugged. Car came in no start. Low fuel pressure and low volume . Did primary pump first car ran , but not as expected. Scanner data showed 400 psi at idle. Then replaced high pressure pump. Now I get 420 at idle.
