Icarsoft scanning tools
Location: Oranjemund - far south western corner of Namibia , orange river mouth.
Hi there from Newby,
I know the I930 is the most popular / cheapest diagnostic tool for Jaguar but I wanted to ask if I should rather go for the V2.0 to be able to use the DPF reset function (will I ever need it). Are they both easy to use and what other manual is needed for decoding and pin pointing error codes with these tools? Maybe the LR2? Can someone with experience on these 3 models pls let me know which one is easiest to use (understand) & to decode and will I need all functions for DIY on the V2.0 or will the I930 be sufficientWill be used on 2013, XF 3.0 D S
Thank you
Thank you
Received 3,259 Likes
I got an i930 a few years ago to use on my XFS then on my XFR and then on the F-Type.
It reads almost every possible error code but it doesn't show the last two digits of the code which would otherwise really narrow it down.
It also shows a wide range of readings and parameters which are useful for diagnosis of problems.
It resets/deletes error codes but doesn't do any of the fancier functions like resetting the service required message, checking and resetting DPF readings, initiating a forced DPF regen, putting the EPB in service mode etc etc.
A few months ago I got an LR 2.0 which does all of those things and more, but it still doesn't show the last two digits of the error code, I believe only SDD will do that and maybe some other rather expensive code readers.
All the codes are explained by both readers or you can research the internet for more detail.
The LR 2.0 is a fairly big step up from the i930, but it costs around twice as much and it's a bit more fiddly to connect up as you have to re-attach the OBD2 cable to the device each time.
But if it does what it says on the tin regards DPF functions then it would be worth it for an X250 3.0D owner.
This what the advertising blurb says:
"Diesel Particulate Filter (DPF) regeneration control system, requests the DPF regeneration process while DPF blockage and turn off the DPF indicator."
I presume it is done while the car is stationary (but with the engine running) as it would not be safe to be fiddling with the reader while driving.
Edit - the User's Manual has a little more info but the text is so tiny I can't read it.
But you can download it here: https://www.icarsoft.us/Uploads/down...ies_Manual.pdf
And here is my attempt to copy that part into a pic:
Hi,
Been investigating the functions of the scanner on my XF 3D S. While using the live data function I noticed all the different sensor readings and wondered where one would find what the ideal reading of each sensor should be during idle for instance etc. Would be wonderful to have a document with the ideal perimeters or something like that to diagnose and pinpoint a warn component or sensor.
As BB says, it may have to be done several times if the DPF is getting full. You should keep a close eye on your engine oil level, due to fuel dilution which can lunch your engine.
jimlombardi
03-30-2023 03:34 PM
philwarner
25
06-26-2021 05:43 AM
jimlombardi
US Northeast
01-24-2015 06:20 PM
