Intake Valve cleaning.
Has anybody had the intake valves cleaned on an XFR and did you notice any improvement in performance? My car has just over 113,000 miles on it and it runs and sound well but I doubt its ever had a cleaning and wondering if its worth doing, Also are there any product that can be added to the intake that would be effective in cleaning the valves that wouldn't damage the engine, CRC makes a product called Intake Valve and Turbo Cleaner . I appreciate any input.
Michael
Michael
Michael
Michael
there was quite a bit of buildup on my intake valves. rotated crank until intake valves both closed on a particular cylinder and used combination of various solvents such as you mention and cotton swabs and brass brushes from gun barrel cleaning kits.. soak the intake valves and rub / scrub as best you can and repeat. i must have used 10 cans by the time i felt good about all 16 valves being degunked..
sounds like you are trying to inject a product with hopes it removes the buildup. i can't speak to that, but i also cannot see how it could work since it takes so many miles to build up - it's hard and stuck.. the various solvents slowly soften / melt it.
i sprayed a large quantity such as to completely immerse the deposits and then used cotton ***** to absorb the majority of sludge after if melted it..
i know this is a weird response, but it's what i did.
quite hard to get proper access to do all of this too - really have to lean out and over the engine to properly see in once s/c is removed
The following 2 users liked this post by Adam J:
Paul Fisher (01-14-2020),
Reaxions (05-11-2022)
i did a long while back when i removed S/C to have it serviced / did the plastic change for crossover tube and such
Mike
That makes perfect sense, obviously running something through the intake would not be nearly enough to clean those valves since it took so much product and soaking and scrubbing to get them clean. After you did the job, did you notice an improvement in power and gas mileage and just the way the engine runs?
Mike
Mike
Just to make sure I understood you correctly. You removed the intake tube from the throttle body and sprayed it into the supercharger through the throttle body? Using CRC valve cleaner? And do you agree to those who say spraying such chemicals into your intake system will end up hurting your catalytic converters in the long run especially using it every 6000 km?
Because I have been wanting to do this for a long time on my XFR but I was affraid doing this and spraying stuff into the supercharger may hurt something. When I asked about this on few pages no one was able to give me a definitive answer. I used to do this in my 5.0 XF but it was naturally aspirated model with no issues, in fact I have gotten good results and I had no cats (removed).
Thanks in advance
Thanks in advance
What I need to know is what improvement of any was realized after having the valves cleaned.
I don’t believe that just running a chemical through the intake would really clean the baked on oil, I agree that they need to be manually soaked and cleaned or blasted with media to get them clean however that is expensive and labor intensive and I’m trying to find out if it’s worth the effort and expense.
I cleaned up all my intake valves (exhaust valves were too pitted to recover so I had to replace all 16) when rebuilding my heads during my engine rebuild.
Can't say if it improved anything or not as there was a sizeable gap between drives while rebuilding the engine, but what I will say is that the work it took to clean the valves was significant and I don't think there's a chemical in the land that could effectively clean off valves with heavy deposits like mine had while still not causing damage to e.g. s/c rotor coating or cylinder walls, because I needed a bench drill and wire brushes to get mine clean.
There may well be a chemical that you can use preventatively as @Bigg Will has suggested that could prevent or at least reduce carbon build-up over time, but if your valves have never been cleaned I'd honestly skip straight to having them walnut blasted or similar.
As for whether you'll see an improvement: maybe, maybe not? It should improve airflow into the cylinder but whether that actually translates into something you'd notice I'm not sure. I don't think you're going to find anyone who can give you a solid answer either way. Consider it a maintenance item and find out how much a shop will charge you to clean them.
It's quite a job to do DIY.
Even just removing the supercharger can be quite some work, but honestly my biggest concern about walnut shell blasting with the heads in place - even done by a shop - is debris/walnut not being sucked back out and making its way into the oil system where it blocks channels to the VVT phasers or worse the piston cooling jets.
I know some manufacturers like BMW that require walnut shell blasting as a maintenance item have created special vacuum/blaster attachments that match the inlet ports and it's possible Jaguar dealers have something similar, but really the best way to clean them is by stripping the heads, and really that's never worth doing unless you've blown a gasket (or in my case, spun two connecting rod bearings. Check your oil level!).
I would be more interested in how can we prevent it from happening in the first place,... I am in process of doing a major service on my XFR and contemplating installing new fuel injectors from a 15' XFR and pump and filter to run a factory flex sensor and tune the car on E85. That will help with heat soak issue as well as E85 runs much cooler especially with boosted cars. That is the best my research came up with to fix this problem permanently.
If the car is sold elsewhere fitted for E85 that might work but I've seen Saabs converted and pump was good but fuel lines were not in cars that were E85 for different markets.
Boy, do I feel stupid for never bothering to find out what the heck E85 was. My XJ is a FlexFuel model and there's an E85 station nearby. But I wonder if having the VAP tune changes anything.
Edit: I shot an email over to Stuart and Chris at VAP and they say E85 is safe with their tunes. (super quick response from them) I'm off to the races!
I'm liking E85 very much. The engine seems much smoother and happier, and there's a definite increase in power.
Its odd yours doesn't have the same cap. I wonder if there's a VIN cutoff somewhere. Perhaps my car was built some time after yours.
