Interchanging Jag wheels?
I'm looking at getting a second set of rims for my 2010 Jag XF SC for the winter tires. I currently have the OEM 20inch staggered Selenas (8.5/9.5inch) that came with the car and I need something similar (I already have the winter tires).
So, three questions:
1) Assuming I stick with 20 inch staggered, what other Jag rims will fit the 2010 XF SC?
2) I like the 20 inch staggered Senta. Found a set from an XKR that are 5x108, 20inch and 8.5wide front, 9.5 wide rear. So appear the same. But on the Jag catalogue the front Senta wheels for XF and XKR have the same P/N, whereas the rear wheels have different part numbers. Am wondering if they make two almost identical wheels with different offsets for the two models?
3) Is there a simple database showing the size, detailed specs and fitment of Jag wheels on the various Jag models - I've not been able to find one
Any thoughts and guidance welcome...
1) good question, but anything with same offsets should work, Nevis from XFR for instance
2) yes
3) maybe, need to look on the forum through search or maybe stickies
I used my staggered 20 Selenas for a dedicated winter set with 255 all around and purchased a set of staggered 8.5, 10 X 20's with oem Dunlops. I bought custom bored Savini BM3's with more aggressive offsets to flush wheels with outside of fenders. This was less expensive than trying to find Jag setup. There was a nice set of Mativas on the forum classifieds but I don't recall rear offsets. I really like that style and is rare. I will look at putting 295's on rear when I get new rubber.
2) yes
BritCars (04-15-2015)
Received 3,274 Likes
They will clear the 355 mm front calipers but not the 380 mm.
AFAIK all XFRs have the 380 mm front calipers but some S/C have the 355.
Easiest way to check what you have is to take a front wheel off and have a close look at the caliper, both the 380 and 355 have the number stamped into the caliper.
aliensporez (05-06-2015)
Thanks everyone for the input. On the question of downsizing the wheel, as OzXFR says, that's not possible on the SC due to brake caliper size - none of the 18inch wheels appear to fit, and the same is true for most of the 19inch wheels too.
Specifically regarding the Sentas from an XK, the answer appears to be that they will not fit my supercharged XF. Although they are 20", staggered, 5x108 (just like my XF), the offsets are the issue. They are the same on the front 8.5inch wheels (49mm). However the Senta back wheels for XK appear to be 26mm offset, vs 66mm offset on a staggered setup XF SC - so a long way out...
Back to looking around...
I was planning to buy a 5.0 S/C in 2012- I wasn't a fan of the Dracos, and also needed to run winter tires, so I looked into the OEM options; here is what I found at the time: The OEM 20" staggered sets with correct offsets for the XF were Nevis, Draco, Selena, and Volans; the XK staggered sets do not work as the rear offsets don't match. I favored Volans at the time, though they are a bit Golf/GTI-ish in design. I was planning on running 19" wheels (square setup) in the winter, and the OEM designs with adequate clearance for the S/C brakes were Tamana and Auriga. I ended up buying a 5.0 N/A, so this information is just based on my research, not on actually running these wheels; but hopefully it is a helpful start.
The Mativa's sold already - but they were 1/2 inch wider front and rear than I wanted - and the rear offset was a bit too small. Apparently they are not considered a fit for the XF - maybe due to the offset.
Ok, posted this other places, but one more won't hurt. As late as 2014, XFs could use wheels from S-Types, X-Types, later XJs, and some XKs. I would believe that brake rotor diameter would be the defining feature as to what wheels could be used on any particular car.
Jaguar - it's not an automobile, it's a Motorcar
'08 Jaguar S-Type 4.2 "Satin Edition"
Jaguar - Vehicle Bolt Pattern Reference
(Jaguar _ Vehicle Bolt Pattern Reference)
On these pages you can find Jaguar vehicles Bolt Pattern and Offset. This will help you in determining High or Low offset and bolt patterns of your vehicle.
Discounted Wheel Warehouse has provided this information for its customers to provide the very best service to our customers. We offer a large selection of Jaguar Wheels and Jaguar Rims also Custom wheels, Car Rims, and Truck Rims so please enjoy the web site and choose your next set of Custom Wheels from Discounted Wheel Warehouse!
YEAR MAKE MODEL COMMENTS
2000 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2001 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2002 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2003 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2004 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2005 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2006 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2007 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2008 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2009 Jaguar S-Type 5 lug 4.25 inch or 108mm High Positive Offset
2009 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2010 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2011 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XF 5 lug 4.25 inch or 108mm High Positive Offset
2010 Jaguar XJ 5 lug 4.25 inch or 108mm High Positive Offset
2011 Jaguar XJ 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XJ 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XJ 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XJ 5 lug 4.25 inch or 108mm High Positive Offset
1988 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1989 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1990 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1991 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1992 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1993 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1994 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1995 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1996 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1997 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1998 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
1999 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
2000 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
2001 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
2002 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
2003 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
2004 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
2005 Jaguar XJ Sedan 5 lug 4.75 inch or 121mm High Positive Offset
2010 Jaguar XJ SS Super 5 lug 4.25 inch or 108mm High Positive Offset
2011 Jaguar XJ SS Super 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XJ SS Super 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XJ SS Super 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XJ SS Super 5 lug 4.25 inch or 108mm High Positive Offset
2004 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2005 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2006 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2007 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2008 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2009 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2010 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2011 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XJ8 5 lug 4.25 inch or 108mm High Positive Offset
2004 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2005 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2006 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2007 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2008 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2009 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2010 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XJR 5 lug 4.25 inch or 108mm High Positive Offset
1988 Jaguar XJS 5 lug 4.75 inch or 121mm High Positive Offset
1989 Jaguar XJS 5 lug 4.75 inch or 121mm High Positive Offset
1990 Jaguar XJS 5 lug 4.75 inch or 121mm High Positive Offset
1991 Jaguar XJS 5 lug 4.75 inch or 121mm High Positive Offset
1992 Jaguar XJS 5 lug 4.75 inch or 121mm High Positive Offset
1993 Jaguar XJS 5 lug 4.75 inch or 121mm High Positive Offset
1994 Jaguar XJS 5 lug 4.75 inch or 121mm High Positive Offset
1995 Jaguar XJS 5 lug 4.75 inch or 121mm High Positive Offset
1996 Jaguar XJS 5 lug 4.75 inch or 121mm High Positive Offset
2010 Jaguar XK 5 lug 4.75 inch or 121mm High Positive Offset
2011 Jaguar XK 5 lug 4.75 inch or 121mm High Positive Offset
2012 Jaguar XK 5 lug 4.75 inch or 121mm High Positive Offset
2013 Jaguar XK 5 lug 4.75 inch or 121mm High Positive Offset
2014 Jaguar XK 5 lug 4.75 inch or 121mm High Positive Offset
1997 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
1998 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
1999 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2000 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2001 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2002 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2003 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2004 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2005 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2006 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2007 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2008 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2009 Jaguar XK8 5 lug 4.75 inch or 121mm High Positive Offset
2012 Jaguar XKR 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XKR 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XKR 5 lug 4.25 inch or 108mm High Positive Offset
2011 Jaguar XKR-S 5 lug 4.25 inch or 108mm High Positive Offset
2012 Jaguar XKR-S 5 lug 4.25 inch or 108mm High Positive Offset
2013 Jaguar XKR-S 5 lug 4.25 inch or 108mm High Positive Offset
2014 Jaguar XKR-S 5 lug 4.25 inch or 108mm High Positive Offset
2002 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2003 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2004 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2005 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2006 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2007 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2008 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
2009 Jaguar X-Type 5 lug 4.25 inch or 108mm High Positive Offset
davidladewig
09-03-2015 06:32 PM
innzane
09-02-2015 10:08 AM
