Intercooler pump
Intercooler pump
Will a faulty intercooler pump always throw a code. Im trying to track down SC boost fall off at WOT. Changed the belt which helped a bit due to some slippage. Im getting no codes other than p402 (catalytic converter) however the supercharger pulls well during part throttle then quickly flattens out with WOT. I have a Velocity tune and larger lower pulley good for 450HP. Im not seeing anywhere near that… trying to sort it all out.
bfarrell (07-07-2021)
Because with our tune boost does not fall off. We just set a record for fastest 5.0sc car btw
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 111.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 Supercharged, (stock with Alpha Jag ECU tune), estimated power: 600+ hp, 7.7sec 1.8th mi/95mph
WaterDragon
04-19-2014 10:17 AM
Candy's Kitty
09-19-2012 02:41 PM
