Intermittent P0106 error code?
A couple of months ago, my XF had a check engine light with a P0106 error. It lasted a couple of days and then the check engine light went off. I called the dealer and they said that as long as the light went off, i'm ok. Not to worry. This morning, the check engine light came on again. Same error.
Is is ok to drive around with this error? Is it something that could damage the car if I drive with it? Should I clear the error code and see if it comes back on again?
Help is appreciated.
Ken
Ken
It likely means the car can't get fuelling right but to my mind more importantly right now would be why is it happening.
If you're unlucky it could be water in something really important like the PCM - but lucky if so in that you've been alerted via a code!
I don't know where BARO sensor is in your car but mine is inside the PCM and water would be a scary suspect...
tommy8850
05-25-2012 10:20 AM
