iPhone Bluetooth Failure with Apple iPhone iOS 8.0.2
Phone pairs and docks but no sound coming through the car speakers with inbound or outbound calls. System works ok when using Samsung Galaxy phone running Android.
Visited Apple store in London and the techie reset my iPhone network settings to factory ones and sent me on my way saying it should be fixed. No it isn't!
Next step is to call the techies at Apple who will probably ask me to completely wipe and rebuild the iPhone. Will report further progress when it happens.
http://finance.yahoo.com/news/apples...203706740.html
Jaguar released a bulletin on the iPhone 6 and iOS8 pairing problems. The fix for the mentioned problem is an easy one, but I'm not sure this will address not getting sound through the speakers. It mentions a more specific problem. Regardless, it's worth a try.
"When the Apple device is connected to the car system and the call is received there is no option to answer or reject the incomming call on the system. The steering wheel controls also have no effect. The touch screen continues to display the phone screen. The pop up screen to answer or reject the call is not shown"
Caused by the new iCloud "iPhone Cellular Calls" feature.
Go to settings, select iCloud, turn off the above feature.
Then delete the car's bluetooth pairing from the phone and turn the phone off.
Delete the iPhone from the car's system.
Power the phone back on and repair it to the car. Should work as normal.
Good Luck. P.S. I hate bluetooth.
veeter2 (10-15-2014)
Just an FYI this is a known issue with IOS 8 and should be fixed in IOS 8.1 per Apple's iOS 8 update breaks Bluetooth car connections, fix may be coming with iOS 8.1
ajd (10-17-2014)
Thanks for all the comments and advice. I a using an IPhone 5 with iOS 8.0.2, which is still appearing as the latest OS version.
In my settings/iCloud, there is no cellular option, so unless I am looking in the wrong place, this is not something I can see.
I see there is talk of a new OS version being available, so maybe a fix will come from that direction.
I recently replaced my old XF with a newer model. Since purchasing it my i-Phone5 operating system has been upgraded to iOS8 and now, when connected via the USB port, I can only get any music out of the speakers if I control from the phone and then the music title etc. displayed on the screen is often different from what is actually playing through the speakers.
I had the same problem of not getting sound out of my speaks once my i-Phone was updated to 8.0.2 and I took the advice shown on this forum site to do the following:
1. De-pair and remove both bluetooth connections i.e. i-Phone and car
2. Logout of i-Cloud on my i-Phone
3. Re-pair in the normal manner.
Once I had completed the above my connection works perfectly.
My 2010 XF would dock then undock my Iphone6 via Ipod connection. It was really frustrating since the sound quality from the 30pin connector via lightning adapter was so much better. Long story short, your suggestion fixed the problem and everything seems to be working fine...Fingers crossed and thanks for the great tip.
Im having the same 30 pin problem in my 2009. I was thinking it was an ios update capatability issue but your ipod works fine now, being able to control through the car? After doing the icloud steps?
bydand
09-28-2015 09:47 AM
bydand
09-27-2015 12:00 PM
