issues issues issues smh
hi all.
2009 XF
anyone have an issue when coming to a complete stop and car seems the surge forward kind of like if it was a bad motor mount or the engine bounces or something?
I also have a strange howling noise coming from the passenger side floor area specially on cold starts.
and last but not least is there any possible way that my parking assist might not be working because of the sensor behind the brake peddle?
im new to this and did some research on here but found no answers.
thanks
2009 XF
thanks
I seem to be going through the same issue on cold starts in the morning (hear a humming for the first few minutes). Sounds transmission fluid related. I will probably replace the tranny fluid and pan filter. Mine lurches when I place it into park. I generally put on the parking brake before taking my foot off the brake pedal. If I don't put the parking brake on before letting off the brake pedal, the car will jump a few inches.
If it is while the vehicle is moving the it could be the above still or wheel bearing or CV joint.
If a manual transmission, the throw out bearing can also make noises.
