It's about time! BMC Air Filters
Finally, I have been trying to cross reference for almost a year. And now they make for our vehicles as 3/04/2013. If you don't know about BMC read below or click the link and see for yourself.
WINNER IN ALL CATEGORIES
BMC Air Filters are by far the most successful filters in every sports category, since they equipped the champions of Formula 1 (9 titles), American Le Mans (10 titles), Le Mans 24Hours (11 titles), DTM (9 titles), Superbike (2 titles), AMA Superbike (1 Title), Suzuka 8Hours (1 title).
JAGUAR | Products Results | BMC AIR FILTERS
All Jagaurs except the XK share the same filter from 2002-2013 you can look at the K&N website and see. So these should be the same as well.
http://www.knfilters.com/mobile/applications.aspx?prod=33-2273
I just ordered a pair of WIX....
Going by the BMC specs below...the little difference in performance with this glorified K&N filter vs a Paper element filter, just doesn't justify the cost of over $180.00 for two filters..
I always used BMC on my car when there was an application for them. I just sold the 2 I got from BMC when I sold my XFR recently. I still have a few other goodies left for sale.
BMC makes a great dry performance filter and I would advice everyone to give them a try in any car you have.
Remove the 6 torx screws and gently lift the lid of the air box up on an angle to take out the old filters. Replace with new filter the same way the old one came out but make sure you are gently when closing the air box back down not to pinch the seal or filter so the screws go back in easily and without resistance. A good seal is needed so just be gentle and take your time. It is very fast and easy.
psinsyd (07-01-2013)
Thanks!
Is there a need to loosen the hose clamps so that the air box lid moves around more easily?
Thanks. I just loosened the 7 torx screws on each air cleaner -- it turns out they're captive, so they stay in place after they're loosened. Not loosening the hose clamp as you advised saved me from wasting another 5 minutes per side.
All told, I replaced both engine air cleaners and the cabin pollen filter in under 20 minutes.
Beardy
09-18-2015 10:00 AM
