Jaguar Mechanic broke my engine cover [Pics!]
More than likely since anyone who has replaced the pulley with an aftermarket pulley
has had to rent/buy/borrow the pulley removal tool from the vendor or cut the pulley
off.
Since Jaguar considers the unit to be an non-serviceable R&R, there probably isn't
an official service tool.
off.
The following 8 users liked this post by xjrguy:
Blackcoog (08-07-2015),
Cambo (08-07-2015),
damienedwards (08-15-2015),
JgaXkr (08-06-2015),
Mikey (08-06-2015),
and 3 others liked this post.
Only an idiot would fit an old accessory drive belt to a new engine. I expect new drive pulleys to be on the new engine but perhaps not. Mine is supercharged and I got a new supercharger snout so there's a new pulley and new belt. I didn't bother to look further down. The new heads would be clean which should be enough confirmation that a new engine was installed. Hard to see why a dealer would say they fitted a new engine under warranty and did not but standard practice is to ask the customer to sign the wo confirming the work was completed.
As for whether a new engine or remanufactured engine were fitted under warranty it would be easy to tell the difference. A used engine would not satisfy the warranty in my view.
And just by the by I wasn't casting any doubt it was the original poster with that concern.
Serpentine belts are designed to be refitted. But they do wear out. The labour to fit an old one is more than the cost of a new belt. However, on my new engine replacing the original at only 15,000 km perhaps they reinstalled it. They replaced the water pump though and the supercharger snout, a cat with O2 sensors, the front final drive unit, etc etc, so the saving effected by reusing the old belt wouldn't make any sense. Indeed, only an idiot would think it made sense to reuse an old drive belt when replacing a $20,000 engine and associated parts.
#31
#32
Received 10,916 Likes
All parts used should be listed on the work order
Were they replaced because the dealer discovered a problem with them? Or were they replaced because the dealer thought that replacing lots of things would make them look less idiotic?
I'll explain what makes sense. It involves a simple inspection followed by a logical decision.
If the belt looks good and has not seen much mileage it is perfectly acceptable to reuse it. That makes sense.
If inspecting the belt reveals noticeable or significant wear, or suggests impending failure, then yes, you'd replace it. That makes sense.
Replacing known good parts, however, does not make sense....although some with money to toss away often do so. In most cases manufacturers do not consider themselves as having money to toss away so replacing perfectly good parts under warranty is not allowed. They reckon, quite reasonably, that paying for needless replacements makes them....you guessed it...an idiot!
If any dealer techs following this thread tell us that Jaguar is particularly lenient, forgiving, or generous with respect to needlessly replacing parts as part of a warranty repair then I'd love to hear so, and will gladly stand corrected.
#35
Jaguar has apparently suffered "a number " of Ford manufactured engine failures and all have been replaced under warranty as far as I know. No doubt these failures result from a QA failure at the Bridgend Ford plant or in one of the many parts suppliers to that plant. It isn't a Jaguar issue.
There has been no diagnosis confirmed to me. No doubt Jaguar has no interest in diagnosing the fault as it just be a Ford problem.
#36
Why were all those things replaced?
At a mere 15,000 km (less than 10,000 miles) and two years old I agree refitting the old belt would be fine. I don't think they did but I'll ask. In the description of the parts moved and parts renewed is a reference to "change ancillary equipment and renew ". There is no listing of a serpentine belt specifically. Mind you there's no separate line item for the 8 litres of fresh oil installed but no doubt that was charged to Jaguar. Although, coincidentally my car was exactly due for its first free oil change so maybe not!
At 50,000 km it would make no sense to refit the used belt. A judgment call depending on the service life specified for the belt. Some serpentine belts are supposedly good for 100,000 miles but not necessarily for the length of time it might take to get there. Of course if the water pump was leaking coolant onto the old belt then a new belt should have been fitted.
#37
Received 2,263 Likes
Now that our friend has completely embarrassed himself yet once again with his lack of knowledge, how about we get back onto topic?
I happened to remove the engine cover from one of my other cars yesterday and noticed great similarity to the cover on the OP's car. In the photo below, it appears there are two 'ball and socket' studs that secure the cover to the engine. It appears here that the cover is simply not locked into place. In my case, it just took simple hand pressure to pop it into place.
I'm guessing that the foam was not already detached from the cover when the mechanic was buttoning things back up and it happened to fall off after the OP got the car back.
I think I'd just glue it back into place, pop the cover back into position and call it a day. Or is that too simple?
#38
#39
![Icon Nut](https://www.jaguarforums.com/forum/images/smilies/icon_nut.gif)
![Icon Crackup](https://www.jaguarforums.com/forum/images/smilies/icon_crackup.gif)
#40
So yes, don't be so quick to make mountain oysters out them ...In my case, my dealer gives my car the white glove treatment and not the rubber glove treatment..-..I would hope all JAG dealers would do the same..
