Jaguar Mechanic broke my engine cover [Pics!]
#41
And, Jagular, you make some pretty outrageous and libelous claims about Ford! If you were to compare Ford vs Jaguar engine reliability, I doubt you would find Ford lacking! Hint: think Nikasil, chain tensioners, valve covers and so on.
#42
Doug said CASTIGATE, not CASTRATE! - Although I do like his previous suggestion of drawing and quartering any tech who overlooks something.
The prior reliability issues you refer to afflicted the 4.0 V8 manufactured by Ford in the same plant when Jaguar was owned by Ford. The same engine was fitted to the Lincoln LS.
The Nikasil issue afflicted BMW and others. It was eventually though to be a problem resulting from sulfur content in gasoline.
#43
All parts used should be listed on the work order
"Engine Assembly - Change ancillary Equipment and Renew"
Under it intcludes some components like
- Engine-Stripped - Fuel Feed Pipe - Fuel Hose - Inlet Man Gaskets - kit injectors (RE) - Gasket Water pump - Gaskets for Exhaust - Anti Freeze - Castrol Oil - Cable ties - Oil transmission .
Why was engine replaced. How many miles were on it. Just curious and a bit concerned.
This sound always used to come randomly when I first got it at 72000km = 44738.7 Miles. It would go away but then started coming more frequently where it was there regularly in which the mechanic noticed it. Water pump was changed as a first step, did not solve the problem. Further investigation found low engine oil pressure during hot and cold engine runs. Data sent to JLR in which remanufactured engine was approved under my extended warranty. After everything fitted...the pictures in this post were what I found w/ regards to the engine cover.
I happened to remove the engine cover from one of my other cars yesterday and noticed great similarity to the cover on the OP's car.
It appears here that the cover is simply not locked into place....I think I'd just glue it back into place, pop the cover back into position and call it a day. Or is that too simple?
...it's too easy sometimes to de-ball the dealer's/tech in the moment of frustrations ..But with OP's situation however, he has other mitigating circustances from the beginning...Such as the Scratch on his bumber, the food crumbs in the back seat, the BROKEN engine cover and not being reinstalled properly to name a few
I called the service manager and it seems currently they are not taking responsibility for it. As makes sense, they claim that their mechanics take engine covers off all the time they wouldn't have broke it. Saying it may have already been like that in the first place. I will show it to them on my next visit and then come to a conclusion on whats ganna' happen. Hopefully they will at least fix it since it could just be a simple fix of fixing the joints / foam.
#44
Now that our friend has completely embarrassed himself yet once again with his lack of knowledge, how about we get back onto topic?
I happened to remove the engine cover from one of my other cars yesterday and noticed great similarity to the cover on the OP's car. In the photo below, it appears there are two 'ball and socket' studs that secure the cover to the engine. It appears here that the cover is simply not locked into place. In my case, it just took simple hand pressure to pop it into place.
I'm guessing that the foam was not already detached from the cover when the mechanic was buttoning things back up and it happened to fall off after the OP got the car back.
#45
Just under 10,000 miles the engine let go under acceleration. It laid an impressive smoke screen similar to a competition engine blowing up.
Jaguar has apparently suffered "a number " of Ford manufactured engine failures and all have been replaced under warranty as far as I know. No doubt these failures result from a QA failure at the Bridgend Ford plant or in one of the many parts suppliers to that plant. It isn't a Jaguar issue.
There has been no diagnosis confirmed to me. No doubt Jaguar has no interest in diagnosing the fault as it just be a Ford problem.
#46
I would like to see the final warranty claim to see if they paid for the belt or not. Having done Jaguar warranty (not Jagular's interpretation of warranty) for many years just because a part is replaced it does not mean the dealer is paid for it. You either had an issue with the belt or the technician just decided to replace it. It is common practice for a warranty claim to be adjusted down after a repair is performed. It could be for excessive diagnostic time or parts they feel the customer should have paid for. But as I have said before Jagular knows all just ask him he will tell you.
DPK (08-09-2015)
#48
All my paperwork says N/C which is all I care about.
Besides, this is Canada. We do things differently up here. My dealer is the best dealer in Canada and has been for several years.
#49
Received 10,871 Likes
Ok, now we're getting to the heart of things.
When your thought process stops at "I got it for free" then, naturally, you won't have much actual knowledge or understanding about how warranty administration actually works.
#50
Received 2,263 Likes
Well actually, no 'we' don't in this respect. No difference between Canada, US and anywhere else I know of.
For readers around the world following this soap opera, not all of us in the great white north are borderline trolls that can't resist continually hijacking posts. Most of us are actually the self deprecating type that like saying sorry even when there's no reason, as per stereotype.
Sorry.
Sorry.
#51
#53
Sorry.
Sorry.
I'm not Canadian anyway except with the government's permission.
This thread hasn't been hijacked. All the posts are related to engine replacement and related servicing.
I do note a lot of claims to accurate information lacking any supporting source but nevertheless claimed to be authoritative.
I also note the continued personal attacks made by you as a moderator which is unusual to say the least.
#54
A customer doesn't need to know how it works. This thread was about an engine replacement and observed poor servicing. My experience of an engine replacement was accompanied by exemplary service and very high levels of servicing skill. I spoke to both the chief mechanic and the mechanic who replaced my engine. I know all I need to know about the work that was done and the quality of the service I received. It is very unfortunate that the OP was not treated to the same.
#55
#56
#57
Whatever, Canadian regional coordinator. You do realize that a propensity for personal attack (technically "ad hominem" argument) is the sign of an insecure personality.
What is bothering you eh? Or is it just that Canadian inferiority complex?
#59
Very common for the insulation on engine cover to fall off or crumble into a million pieces. Those covers are a PITA to put back on if the grommets fall of the back. The cowl and strut brace has to come off. Tip for oil changes is to just pop the front off and wege a small block of wood to prop it up.
#60
To Jagular , Mikey and Doug
I probably should not get involved in this and for what it's worth I have to say this ,
I have have read many posts by all three and have to say you all certainly know the Jaguar
product , you have all chimed in helped others on this forum when necessary .
As a forum reader , like many others here , understand what you are trying to explain , but sometimes it can get lost in it's translation , there's a difference of opinion or understanding .
I'm sure the OP got the answer he was looking for
Move on , This topic has had it's run .
As usual looking forward to more of your posts .
Cheers ,
Sid
Cheers ,
Sid
