Jaguar Teases 2016 XF
#41
Evolutionary is great on the outside, but I like a little more revolutionary on the inside. A perfect examples of a revolutionary interior change is the dash of the new S Class Benz or even the current dash of the Audi 8 or 7.
For 2016 only the 2 end air vents will be powered TACKY! why not just use the existing round manual vents from the XJ and add 3 similar styled small vents for the middle above the center display?
The emblems looks too Honda like, the font used for the name "Jaguar" is too blocky.
I hope it has 4, or at least 3 zone A/C, all cars in this class should.
And the center high mounted stop lamp needs to be neon, at the top of the back glass as in Bentley and Audi.
I'm just seeing too many compromises and carry overs in a car that will top out at about $100K, and is supposed to be all new?
#42
For me its not the interior color it the aesthetics, What Jag has done is compromised, and that's fine but at least tie your cars together to your flagship the XJ on the inside.
#43
42 posts and nobody has said anything about the lack of a V8 option? I get that everything these days is going smaller displacement with turbos, but the JLR V8 is used across so many different models I'm surprised it's not even mentioned in the press release, let alone as one of the XF trim level options.
Maybe they're waiting a year or two before releasing a V8-equipped R model?
#44
42 posts and nobody has said anything about the lack of a V8 option? I get that everything these days is going smaller displacement with turbos, but the JLR V8 is used across so many different models I'm surprised it's not even mentioned in the press release, let alone as one of the XF trim level options. Maybe they're waiting a year or two before releasing a V8-equipped R model?
BMW and Mercedes are doing same with their next gen E Class and 5 series. If you wants a V8 you have to buy a Motorsport model.
#45
I just don't understand why they messed with the rear end, each model of Jaguar looked unique (xf, xj, xk, f-type). Now they are starting to look similar to eachother, it will be hard to distinguish the xe and the xf. The f-type style lights look great, on an f-type. No need to start copying it and putting it on all the other models, it doesn't look that great with the rectangle shaped taillights
nasa25 (03-25-2015)
#46
Yawn. It doesn't move me one way or the other. It's evolutionary which is fine by me being that it's only the second generation. If you believe Jag, it's the driving dynamics that will be revolutionary.
The trend for manufacturers to make all of their sedans look basically the same (just in small, medium and large sizes ) is a little annoying.
#47
It is always a bummer when a new model shows up with a radically different styling, making the older model look instantly aged. In this case we have no such worries. Only some knowledgeable enthusiasts will be able to tell the difference between the outgoing model vs. the new one. I'm just glad I grabbed the last of the NA V8s with my '12 model.
#48
Wanted to take a minute to digest it before commenting. Here's my list:
1. I really don't like the vertical pieces of black plastic the run on the outside of both lower air grilles on the white car. They don't look elegant at all and they feel tacked on for no reason.
2. Is it me or do the side vents now look just like an M5's vents? They looked good vertically, why change it to look like the competition? If the vertical pieces and these vents were painted body color, they might not bug me as bad. The white car looks like a black pack car so maybe that could be avoided, but otherwise, straight to the paint shop for me.
3. I don't like the Jaguar below the leaper, but that can be fixed quite easily.
4. Not sure about the interior, especially the tiered dash. Didn't the Nissan Maxima have a similar look a few years back? I'll wait to see it in person though before I protest too much.
5. I think they really missed an opportunity to put the wood all the way across the top of the doors. To me it creates too many lines and it looks choppy. Not horrible but could have been better IMO.
6. Not so sure about the accordian door for the cup holders. Could be ok in person and it would get rid of the constantly open panel and the inconsistent panel fade that occurs with that. So jury is out to see how nice it actually is.
7. I really, really, really hate the latch on the glove box. Doesn't say premium at all. I know a lot of people hated the button, but I haven't had any issues with mine (don't use it much) and it kept the dash sooo clean looking. That alone might make me choose a darker interior color. The photo of it in the light interior was not good for me at all.
8. On the R, they absolutely have to put the R logo on the metal portion of the dash to the right of the center stack. Otherwise, it's just too bland. The surface looks interesting in the close up photos though.
9. Not sure about the vents either. The center ones might not be very distracting in person, but the side ones should go across the entire metal portion or be centered on it. They look odd being pushed up to the top.
10. Not a huge fan of the flattened front grill. I think it's for european pedestrian safety and Merc has been doing this to all of it's cars and they all look wrong now. This is better than theirs, but not a step in the right direction (and I did mean the pun since it's for pedestrians)
11. Finally, the diagnonal part of the rear window is really distracting to me. Looks like they tried to make it XJ like (ie different than everyone else), but to me it's just a bit awkward and forced.
After all that, I'll probably still get one in a few years though. Or I may just upgrade my daily driver and keep mine long term. After all the depreciation, I can afford the maintenance if I don't have a payment. A lot depends on if it's got soul. That's the reason I have mine. If the new one feels like an M5, KYANITE isn't going anywhere...
![Icon Naughty](https://www.jaguarforums.com/forum/images/smilies/icon_naughty.gif)
The following 3 users liked this post by 2010 Kyanite XFR:
#49
I'm not overwhelmed by the interior. Also I hope the configurable dash has a better set of instrumentation where the tach is not a secondary gauge concentric around the fuel and water temp. The top of the dash looks a bit like a poorly fitted dash cover. I also agree with the statement of the grill being to vertical.
#50
#52
#53
#54
Can anyone speak on the type of sunroof/moonroof there is on the car? Looking at it's size, it is either a pop-up (i.e. Audi A/S5) or it opens on top of the roof like the XJ. A pop-up sunroof would be out of the question for me and a sunroof like that of the XJ leaves me luke warm.
#55
#56
#57
For all the negative remarks I still think this is the best looking car in its segment and an improvement over the current XF on every dimension and from every angle. The front end looks superb.
As for the interior, while it could be better, I noticed another nice car which doesn't have full length wood panels on the doors: The Mercedes S65 Coupe. Would love to see this in person.
#58
#60
The next couple of years at Jaguar are going to be pretty big, XE, new XF, F-Pace(maybe they'll change the name by then). As for this XF, I think like the current XF it'll be much more appreciated in the metal. I know I have the refreshed version but it seems to me that everyone gawks when they see my car and in my eyes this new XF seems to improve upon that.
