Jaguar XF 3.0D fuel injector replacement
I had a strange breakdown on my jag xf 3.0d 2012, that has 80 000 km (appr 50 000miles). I got a low coolant level alarm and before I could pull over the car switched off. It wouldnt start again. The dealer diagnosed that the starter motor had failed, the same time as there was a coolant leak. I find the 2 failures too co-incidental not to be related particularly given the mileage. In addition the dealer informs me that the injectors need to be replaced, all of them, and that it is a sealed unit. They are not able to repair the injectors or replace only that which needs to be replaced because it is a sealed unit. Currently quoting about $6000 to repair. What are your views on why the failure occured and if they are related.
Received 3,239 Likes
Very few diesel XF owners on this forum, you are better off heading on over to the Pommy forum where there are literally thousands of 3.0 diesel XF owners, here: Jaginfo - Jaguar XF Forum
