Jaguar XF air vent Problem
so i have found the Problem it was the PTC Heater. When i unplug the ptc Heater everything is working.
now is my question for change this part is very complicatet. So you say i dont need this part and can go to a garage and they program it out?
Neither. You want to disconnect the auxiliary electric heater. On my 2009 XF 3.0 diesel, at the heater, a small green/white wire goes to it. Disconnect that. Your wiring may be a different colour. If this works, go to your garage & get them to program it out too.
I downloaded both the files above but couldn't open them & I can't find a decent diagram for you as I'm doing this on my phone. The S-type had a diesel powered Webasto auxiliary heater. With the XF range they changed to an electric one. It's purpose is to help heat up the coolant quicker in cold weather, so the engine & heating warms up quicker. Do a Google search for 'Jaguar XF auxiliary electric heater' or ask your garage. Mine was easy to get to, but I have a different model.
wallett (03-09-2022)
That looks like the part but that number didn't match anything I could find.
I unplugged mine & ran with no problems for about a month; I then learned it could be programmed out & had it done. That was nearly 3 years ago.
Their primary use is for cars in countries where it gets REALLY cold. Think Norway, etc.
Glad you got to the answer, my one took over 5 weeks of looking & only found it as there was a multimeter attached when it happened to spike. So we'll call that 20 euros 😁😁
yes is thw Part 21 in the Diagram. I have unplug the red and Black Cable and everything works now.
#31
It's only the passenger side in a right hand drive car, but yes, it's the left hand footwell.
It is located to the bottom left of the entertainment unit/radio etc.
Uncover the material underneath the dash in the left hand foot well and it will be up to the right. The big red and black cables are obvious once you see them.
#32
#34
#35
#36
#38
#39
vent problem xf
Same problem on my Jag 2012 2.2d
Thx to this thread problem resolved
It's on the left side in a left or right hand drive car,
Take away the blue latch with a n isolated screwdriver then gently pull out the copper +plug no need to do the negative black cable
Isolate it immediatly whit tape.
Thx to all
Thx to all
bluejaag
04-18-2023 08:35 AM
