Jaguar XF display screen flickering / flashing
Hello,
on my XF SV8 (2009), modules under driver seat was missing (used car).
So no Bluetooth or USB audio (I have premium audio Bowers & Wilkins).
I have found used Bluetooth Phone Control Module 7G9N-10D893-AF and installed it,
Bluetooth is working fine now (great!), last think to fix is USB/iPhone audio, the cable is rusted and need to be replaced (Ipod to AUU Module Wiring Harness Loom C2Z4708). What else I need to fix USB/Ipod audio? Only new C2Z4708 cable?
I have console USB/AUX/iPod socked in place.
Hello,
Hi, this module in metal box is missing + rusted ipad cable (connector on module side). What is the Jag code of this module? I have there only bluetooth module (plastic case)...
#28
#30
Yes it's the Bluetooth module, all you have to do is unbolt the driver seat and take off just a little bit of the mat floor and work your way Under it but if you want space to work a suggest you take it all off. the hardest part to put back is Under the jaguar panel but I think you can take them off too.
#31
#32
Hi, I bought the APM from the ebay and fixed rusted MP3 cable, but there is another cable which need to be plugged to the module and I cant find it in car, this black square connector, any idea what cable I need?
#33
Second metal box
I'm reviving this thread in hope someone can help. I have had the same flickering screen due to flooding of the driver side floor pan. I have purchased a used Bluetooth module but it did not work.
My question is if the bottom box needs to be changed as well. They are interconnected and it seems work together. The board on my blue tooth module looks OK but is was wet so I guess its history. The bottom metal box however looks in dire condition.
Thanks for any input.
#34
#35
#36
#37
Change both
#38
The fist time I only changed the bluethoot module and it blew and couple mounth late .. I changed both box and no problem since ... I sugest you change both but it's expensive so check on ebay first ! And check all other component under and around the flooded zone because it might have been touched too! And when you reinstall the module I sugest you let some space in between the box module and the floor otherwise water will always touch it !
#39
I had the same issue with mine last month. Went out and bought a Bluetooth module after reading this post and still didn't fix the issue. I finally broke down and took it to a Jaguar dealer. Wound up being the 30amp radio fuse in the trunk. They said all the modules checked out fine. I even had them put the original BT module back in the car. If anyone is looking to buy one of these let me know. I have an extra one.
mbrown26 (12-06-2019)
#40
