Jaguar XF Navigation DVD 2010-2011
Hello every one
I am looking for the new version of Navigation 2010-2011 for my 2009 XF /SC ..is there any sort of group buy going on which I can get in .. or is there any torrent link any one car provide me from where I can download ... I need for North American / Canada
How do I actually install the maps onto the system? I'm still waiting for the delivery of owners manuals but got some map discs in the mail today from ebay. I'm going to assume i put them in the CD player and it prompts from there? Anyone done this before? Lemmeno!
Thanks!
Thanks!
Thanks!
Thanks!
CAUTION; when this disc is installed, it will update the Nav system software to correct an error for 2009 and 2010 vehicles. It takes about 10 minutes to do this if I remember correctly.
P.S. If your menu screen has a "cancel guidance" command in the lower right side of the screen, you probably have the Nav software update. Then check the Nav unit disk to see if it's a 2010-2011 version before ordering a new disk
Last edited by Jerry S; 03-27-2011 at 11:09 AM. Reason: Corrected location of "cancel guidance" command
Redjaguar100 (03-31-2011)
Sorry, I just looked at the disc case and discovered that I had purchased the 2009/2010 versions that also fixed the software problem. Bad memory. Anyway, any Jag dealer should be able to give you the Jag or Denso part number for the 2010/2011 discs.
Hello every one
