Jaguar XF rim question...
Hey guys,
I'am new to Jaguar and found rims that are for sale that came off of a 2009 Jaguar XK. I was wondering if these rims would fit my 2009 Jaguar XF keeping in mind that the bolt pattern seem to be a bit different on both Jag's. Any advice would help. Thanks in advance.
Thank you for the prompt response. The specifications of the XK wheels are as follows:
19x8-1/2, 10-SPOKES, FRONT WHEELS
19X9-1/2, 10 SPOKES, REAR WHEELS
5 lug, 4-1/2 bolt pattern.
While the XF wheels are:
19" x 8.5", 5 Lugs, 11 Spoke, 49mm, bolt pattern of 5x108.
Would these sit fine on the Jag?
Dayzel108 (09-01-2013)
I wish I knew what the offset for the wheels were, but I am unable to find that information. I'm questioning how black finished XK rims would look on my white XF.. I'm in a debate and am afraid to ruin the beautiful luxury look of the vehicle.. Any opinions? My situation is, i recently bought a premium luxury 2009 Jaguar XF and the rims have been repainted in a poor fashion… So currently, Iam stuck between either buying these black rims or just repainting my rims..
Offsets aren't terribly important or rwd vehicles.
Coventry wheels lists the same figments regardless of model year and they are a well known aftermarket jaguar wheel supplier:
http://www.coventrywheels.com/fitmen...aguar&model=XK
There is a very good wheel and tire size calculator just posted on the Wheel and tire forum by badger84. It has an illustration for changes in tire and wheel sizes. It wIll very clearly show the impact of a change in offset. Offset can be important to brake clearance and appearance of the tire in relationship to the wheel well.
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
It's very important but only most of the time, not always.
On fwd it can be critical to safety although there is usually a range of safe offsets even for fwd.
On awd it can really affect handling under slippery conditions so I wouldn't mess with offset on any awd car.
Rwd is a bit different. I personally would not fit the "wrong" offset to my car but there is often a big range of safe offsets to use.
I think we agree that ideally you should always fit wheels within the factory approved range of offsets if possible. If you decide to depart from that make sure you know what you're doing or seek expert advice.
That's all I meant.
That's all I meant.
Swimref (09-13-2013)
