Check the box you have is solid state with low input current - if it drives relays from the lighting circuits the feedback current from the relay coils is very likely to kill the outputs on your RSJB.
I believe the wiring colours on the top left connector of the RSJB are:-
Violet-Orange - Right Stop
Grey-Brown - Left Stop
Green-Brown - Reverse
Grey-Orange - Left Indicator
Green-Orange - Right Indicator
White-Orange - Right sidelight
Violet-Green - Left Sidelight
Hi mate thanks for your reply 👋🏻
These below are the colours I have going into the the rear lights, should I not connect near the lights themselves and go near the RSJB? Do you know where abouts that is please?
RH tail light Violet and brownGreen and orangeWhite and orange BlackGreen and brown LH tail light
Violet and greenBlackgreen and brownGrey and orangeGrey and brown
Honestly appreciate your help as I'm due to collect the caravan this Friday
I found these drawings aswell but just trying to make head or tail of it 🤔
It doesn't matter where along the wires you connect, it's possibly easier near the RSJB, as they're all together, and it's inside the car, if you connect outside immediately behind the light clusters, you have to deal with water proofing, and feeding / sealing the wires through the grommets into the interior ( presuming that's where you'll be putting your new module ).
The RSJB ( rear smart junction box ), otherwise know as BCMB ( Body control module B ), Rear junction box (RJB) and Auxiliary junction box(AJB) ( why do they need four names and acronyms for everything ), is the "fusebox" on the right side of the boot/loadspace. It's actually a computer that happens to have a few fuses fitted. There's a pull-out door on the sportbrake if you look carefully, and I believe you have to pull the carpet type lining out on the saloon ( held in by a few push clips. ).
