Jaguar XF whirring noise.
Old 09-15-2017, 03:20 PM
Hitchhiker's Avatar
Default Jaguar XF whirring noise.
Hi. I have a Jaguar XF, a late 2008 model, Petrol, saloon.
And I have a whirring noise coming from the engine bay, lower near side (UK)
It whirs for about 30 sec then stops, it only does this on a cold start up. At all other times she quiet as a mouse.
There are no error messages on the dash either.
I do hope this jogs someone as its frustrating not being able to fix it
Old 09-15-2017, 03:29 PM
GGG is offline
Received 16,856 Likes on 12,186 Posts
Welcome to the forum Hitchhiker,
I've moved your question from Jaguar Forums Feedback & Suggestion Centre to X250 forum. This is the place to post technical qustions about your model.
Hitchhiker (09-15-2017)
Old 09-15-2017, 05:22 PM
Datsports's Avatar
It might be best to disconnect the supintine belt . And see if this still occurres .
That will at least help narrow it down a little . And hopefully rule some components out .
Old 09-15-2017, 05:25 PM
Hitchhiker's Avatar
Thank you I will try that.
Old 09-16-2017, 12:46 AM
Bigg Will's Avatar
Its probably the emissions air pump.
Old 09-16-2017, 08:37 PM
Mr Sharky's Avatar
It could possibly be the alternator too. Sometimes after start up, they make up for the power lost during the engine starting process when amperage draw on the battery is high and then drop when the battery gains what was lost.
