Jaguar XF (X250) Estate Reversing Lights Always On
Hi All,
I am wondering if someone can help with this weird problem I have developed with my 2014 (X250) Jaguar XF 2.2 (TDi4 163) Diesel Estate.
About two weeks ago I noticed the reversing lights are always on. It doesn’t seem to matter if the automatic gear box is in drive, park, reverse etc,
Even when the car is not running and locked they are still lit up.
The only way I have managed to get them to go out is to actually disconnect the battery.
I have been trying to work my way through the wiring by looking at various diagrams I have found online but no joy so far.
I am thinking it could be sometihng to do with the computer or CAN bus but I will be honest I haven’t a clue.
Has anyone had this issue before? Or does anyone know of anything I could try?
I spoke to Jaguar and they want £175 just to run some diagnostics so I want to avoid that if possible and see if I can sort it myself.
Any help or advise would be greatly appreciated.
Thanks in Advance
Tony
Thanks in Advance
Tony
Hi All,
Thanks in Advance
Tony
Thanks in Advance
Tony
haven’t a clue where that is though!!
gearbox area ish!!
Hi All,
Thanks in Advance
Tony
Thanks in Advance
Tony
The green/blue wire on the second top connector on the left of the RSJB powers the reversing lamps, I'd suggest first checking the voltage there, ( presumably 12v if the lamps are on ), then disconnecting that wire. If the lights are still on with the wire disconnected it seems the logical explanation will be a short in the wiring ( to another live wire ) somewhere between there and the the lamps.
