Jailbreak Tune, Pulley, Muffler Valve Delete & X-Pipe
You really can't go wrong with them. They are great guys who are well educated (Bobby has a law degree and Matt has an MBA) and committed to their business. They are now working with GSR Autosport in Anaheim and HG Motorsport in San Diego, both well know and respected euro import shops in SoCal.
But if you want both tune and pulley you have to go to GSR as I understand that HG isn't comfortable doing the pulley (and I'd just do tune first anyway). They can dyno there at HG although it's a Dyno Dynamics dyno so numbers will be less than mine shows. They do have a correction factor that appoximates Dynojet numbers (which are always highest) which seems pretty accurate based on some info I received from Patrick813. Another option is to go through ETG for the pulley as they have a puller that can take off the stock pulley without cutting.
As I said before, since you have a stock supercharged, get the tune first and decide if you need more. You're going to get a huge bump just from the trim level (470 to 510 bhp) and the tune adds a bunch more (490+ rwhp with 460+ rw torque). I think it was easier to drive with just the tune. Now I have so much power down low that it requires such fine motor movements of my ankle to control. Fun but not as easy.
Let them know I sent you and they will take good care of you. And let me know if you have any further questions.
BostonKiller (09-07-2015)
Thank you, sir! I am actually good friends with HG Motorsports, plus they are local. So, I'd definitely let them do the tune (and dyno).
I have not decided when to tune (my car has only 800 miles as of now), but I will most likely skip the pulley.
Again, great to see such increase in power!
P.S. So, even though from the factory my motor is rated lower (470 vs 510) than yours, the tune will be equally effective?
That is correct. The power difference between the XF Supercharged and the XFR is purely ones and zeros. The factory tune limits power output for the XF Supercharged. Mechanically, the XF Supercharged and XFR are the same.
I don't have any experience with race gas, other than I loved to smell it at the motorcycle races, but have heard it doesn't always have the desired effects because the tune doesn't take advantage enough for the cost.
Any additional input?
#28
Bobby was curious what it would do with 100 octane. Said it sometimes takes a while (up to a full tank of gas) for the ECU to advance the ignition enough to make a big difference.
When I was part of the IS300 crowd I watched a guy go from a daily driven 93 octane map on his GTE swapped IS (~550hp I think) to over 790whp on a C16 dyno pull. He brought a 5 gallon can of it to the dyno day and made sure his tank was already low before filling up.
Race gas makes a HUGE difference. I made over 110hp/110tq more on the VP110 (leaded) map vs 93 octane on my old STI. If you have multiple maps for different gas, the ECU doesn't need to learn to make the adjustment, it should already be calibrated for. If you're gonna do a race map I would do it on the highest octane UNLEADED you can find (I ran leaded on my STI because it was catless). C16 is preferable.
#31
Race gas will let you stay maxed out on boost and timing. From my experience most cars will run max timing and boost until the computer hears detonation, then timing and/or boost is backed off. The computer doesn't so much see the octane, as much as it hears engine killing detonation.
#32
That is the biggest issue I have with tuning these cars, I guess my access port spoiled me when I had my STi.
Is the Jag computer fully unlocked or do all the tuners take a XFR-S or XKR-S tune and modify it?
Adding launch control and flat footing shifting on a car that was not originally designed with it was awesome.
#33
Jailbreak took my stock XFR tune and modified it based on dyno time and laptop skills to get the final product. They took off the top speed limit and other things as well. Not sure how far you can go, but Jaguar doesn't "help" tuners as some manufacturers do by giving access to code. They had to get a special software tool to even get access to the ECU.
And flat footed shifting is standard on the XFR ...yes I'm being a smart ***.
#34
#35
The other way is the engine control computer actually keeps a regular count of the OBD access tries. This is what the State can see when you get a SMOG here in CA with the new STAR Smog check, the STAR smog only checks engine sensors and OBD access attempts, too many access attempts could mean a smog guy was trying to tweak you into passing. This will be the future norm fellas.
#36
Yeah that's the way to do it versus off the shelf tunes. Boiler, I had several high hp Subies and actually had the original V1 Accessport. The OTS tune back then was absolute garbage, once the Protune capability came out there were some good things that tuners were doing. I also used the TurboXS UTEC with selectable map shifter buttons (that was SWEET) and my STi had the Hydra EMS from Element Tuning (tuned by Phil Grabow @ Element). I do miss those Subaru's a little....except when they broke which was a lot
I wish we had a hand held tuner for the Jag computer.
#37
Ok. I guess I was mistaken when I published my dyno numbers from Saturday. That's what I get for putting something out half baked. I received the WinPEP files today and when I went to put it all together, I realized the 532/496 run was on STD correction and not SAE. After changing it to SAE, it was 520/485. It's still a bit better than expected but not "WTF is going on here" either. Still extremely happy with the result. I initially wanted to get back to the stock bhp ratings of 510/460 at the wheel. Done and done. And it's been very drama free except for the supercharger coolant pump issue, which has nothing to do with the mods.
I've attached the stock run, the run with tune and x-pipe only (with an asterisk) and the tune, pulley, x-pipe and intake run as well as the chart with AFR below. I give the tune and x-pipe run an asterisk because I don't know if the supercharger coolant pump was functioning correctly at that time or not. I believe so based on AFR, but it's interesting for comparison either way. What I find interesting is that nowhere in either the hp or torque curves do any of the runs come anywhere close to one another. Just more power with each level with no penalty. I haven't taken any time looking at the power listings, but I'm curious what the biggest increases are at each level.
I also attached a chart of all 5 runs for both SAE and STD correction. The consistency is why I've decided I don't need water/meth injection. In fact, the 4th run was the best so no heat issues to speak of. Never would have expected that.
Let me know if you have any questions.
#38
Received 3,258 Likes
#39
I hope you get your situation figured out soon.
#40
Thats great info!!! Great work......
Really want to go down the custom MAP route with my XFR after completing some further intake and exhaust work. I'm in the UK so can pick up 98/99 octane fuel really easily so will run the MAP on this........as a base line you say you had 458hp......thats only a 10.2% drive train loss to 510hp......is it really that low?? Just watched a Lambo LP670 Murc make 548rwhp.......yours aint that far off!!! happy days!!
