Join Jaguar Timing Chain Class Action
Info here
If you are interested in finding out more about this matter or if you are interested in participating, please contact Gary S. Graifman at (888) 608-9232 or via email at ggraifman@kgglaw.com.
Rockland County, New York
747 Chestnut Ridge Road Chestnut Ridge, NY 10977
View on Map
Bergen County, New Jersey
210 Summit Avenue
Montvale, NJ 07645
View on Map
845-459-0001
Jaguar Class Action Lawsuit
View on Map
210 Summit Avenue
Montvale, NJ 07645
View on Map
845-459-0001
Tried it.
They never got back to me, despite my (at the time, what I felt was) valuable experience in tearing the block down and getting photos of damage caused by slack timing chains. Also, note the years that are covered in the class action are only 2012-2014, despite the fact that earlier cars such as my 2010 obviously have the issue.
Finally, unless you're a lead claimant on one of these actions you're likely to end up with a check for the square root of **** all.
Just my 2c
Just my 2c
JLR knows of this problem and have a TSB to fix this on the LR side. It affects 5.0 engines produced from 2010 to 2012 mainly. They changed the timing chain parts for 2013+ JLR cars, so you don't see this ticking time bomb issue on the newer cars.
BigTurk (12-16-2019)
Which makes the fact that the class action only covers 2012-2014 doubly odd.
Received 3,274 Likes
Although I would have thought this action was being taken under the Magnuson-Moss Warranty Act and I don't think that has a statute of limitations.
What they will do is discovery and figure all that out ( including Land Rover)
I tried to take advantage of that TSB a few weeks ago, and they told me that because my car was out of warranty (2011) I wouldnt quality. is this true?
As far as I am aware, only LR's had a TSB to address the timing chain issues. Jaguar pretends to be unaware of the issue even though it is the exact motor, except for the oil pan and a few other bits. Is this the TSB you referred to the dealer: https://static.nhtsa.gov/odi/tsbs/20...56266-1292.pdf
Special Service Messages are similar but are more aimed at passing on information to the technicians.
Service Actions cover work that needs to be done to cars next time they come to the dealership for servicing and usually expire after a few years.
Recalls are urgent fixes for potentially dangerous issues and the current owner should have been contacted to arrange a time for the car to be repaired.
Recalls are therefore the only thing that might still be done on an early 5 litre at no cost to the owner.
Does anybody know if a similar notice exists for the 3.0 engine?
Current Hers: '13 Lexus ES350
Current Mine: '15 XF (X250) Portfolio AWD
Jaguar - making mechanics out of customers since 1935
