Key Fob Programming
The following 3 users liked this post by Carlos Saez:
bealzabubba (12-14-2020)
Carlos Saez (01-09-2021)
Had a question, i know this is an old tread, but does the H100 add the new keyfob to the system or is it just copying the original key fob.
I made two “new” fobs using the OBDSTAR H100 and both needed a working key in close proximity to do so, so I’m assuming there is some “copying” involved?
First one I made from the damaged original I had and second one I made from the fresh fob I just programmed.
FWIW…One was made using a brand new “knock-off” fob and one using an original Jaguar fob that had been wiped clean.
Ken Dreger (12-31-2023)
My problem is this. The transponder within the key is working as I can start the engine, however before using the key to program it to the car I cannot make the car enter the key programming mode by flashing the head lights etc. The light on the J panel does not light up and the buttons on the key do not show any reaction from the car. Talking to Jaguar mechanics it is obvious that I seem to know more than they do gained from forums such as yours. Any suggestions.
MR. CJ
12-28-2014 06:13 PM
