Largest tire size on XF
OK. What is the largest tire size anyone has fitted on a stock post facelift XF. Even the pre-facelift can chime in too as I think there are no changes in the wheel well. Post pics if you got 'em please !!!
I just bought a set of 275-35/19's that came off an F Type from a fellow forum member. He has a drop and they still cleared. Will I have any issues when I go get these installed?
I have looked on tire rack and they have a 280-30/20 size that shows will fit the XF. I think this is going to tight. Cant wait to get them on !!!
Received 3,239 Likes
Stock sizes for the XFR are 285/30/20 rear and 255/35/20 front, and this still gives plenty of clearance all around. The XFR wheel wells etc are identical to the rest of the XF range. You could easily fit 295/30/20 on the rear, and possibly even 305/30/20. I have also seen 21" and even 22" rims on an XF, I would guess with 25 or 20 profile tyres.
On the front 265/35/20 will also fit easily.
So the 19" rims from an F-Type will fit with miles to spare!
I'm curious what sort of error messages you are getting. How would the computer "know" what size tire is on the car? It would have to have some sort of secondary input independent of the wheels for comparison, like a GPS signal or something to know the speed did not match the revolutions. I.e. if its 7.5% off, the computer only knows the revolutions and thinks you're going 60, but only you know that you are really doing 64.5, maybe using more gas than normal for 60, but that could just be the case with a headwind or going uphill. Unless maybe its detecting a difference in size between the front and rear?
widest tires on stock XF 18 inch rims I just installed 315/35/18 looks alsom just like it was made for the track.going to now put 285 or 295 on front.
As a data point, I am running 245/45R19's on stock Caravela 19" wheels and no spacers of any kind. This size is 27.7" tall (per Tirerack site) and does not rub. However, you definitely cannot go any "taller" with this wheel arrangement without rubbing.
Attachment 150752
Attachment 150752
The stock sizes look fine and seem fine on my car
BTW are those staggerd wheels?
