Latest service
Old 02-23-2012 | 12:09 AM
dannygjatt's Avatar
Default Latest service
So after months and several trips to the dealer, they changed the rubber seal on my sunroof and a busted clip (retaining clip). Car is rattle free as of now. 2 other problems have arised. The fuel gauge is not reading my range correctly and the 3 little lights by the roof switch do not turn on when i open the doors. Anybody have similar issues?
Old 02-23-2012 | 07:07 AM
XeNoMoRpH's Avatar
I currently have a rattle and they supposedly replaced a broken clip in the sunroof area. Still rattles over every bump, so back it will go with the many other issues...
I accidentally touched the middle light and couldn't get it to come back on when I opened the door. You have to touch it for a couple of seconds and that will re-enable it. Your owner's manual should have the procedure in it.
Not sure about the fuel gauge/range issue, but hopefully someone can chime in.
dannygjatt (02-24-2012)
Old 02-24-2012 | 11:08 AM
dannygjatt's Avatar
Will try the to re-enable the light, but it works fine other than when the door is open then it does not turn on. These cars have so many squeaks and rattles, it will drive you nuts!
Jpav27
US Northeast
12-17-2021 06:40 AM
reb1999
09-26-2015 09:41 AM
SD96XJ6L
09-25-2015 11:53 PM
PinnacleWax
Detailing / Car care
09-25-2015 01:46 PM
hhv00586
09-18-2015 09:59 AM
